I'm not a big Linux user, this is probably best posted in their forums not the video forum although I can see the assumed connection. A search of Kodi GetCodingType progressive images not supported by decoder brought
http://openelec.tv/forum/124-raspberry-p...with-3-2-3 'The root file system is read only, change to a read write folder like storage...' this may be applicable.
Do you have 'hide watched' on?
I don't believe so. I will double check when I get home however. They have never shown up in that list, and I have not watched all the movies in Kodi.
Sent from my iPhone
No I do not have hide watched on.
Your looking at 'videos' should you not be looking at library? do you have both 'movies' and 'video' showing in confluence main menu?
edit: sorry saw the other screen cap you do.
what do you see if you select title from movies submenu?
When I hit the movies button, the title on the next screen shows videos
Sent from my iPhone
just wipe the database and start again if you don't care to lose anything.
How do you wipe the database?
Sent from my iPhone
Navigate to your
http://kodi.wiki/view/userdata folder, then the Database folder, then delete MyVideos##. The ## corresponds to the version of Kodi you are using.
PLEASE PLEASE understand that this will remove all your Movie/Tv Show entries (not your actual movie/tv files). There is no getting it back if you delete it.
Once you restart Kodi, it will regenerate a new blank database.
Then rescan library?
Sent from my iPhone
First, enable debug logging from within Kodi.
Then close, re-open Kodi
Then make sure you set content on whatever source you trying to add, and let it scan your files.
Once its done, exit kodi, find the log, and upload to a pastebin site to see if you are still having issues.
Maybe I'm missing something, but I don't see you trying to scan any folders into your library in your log. Can you try again?
This is hilarious, but it fixed its self [emoji23]
Sent from my iPhone
(2016-11-21, 01:43)technoj Wrote: [ -> ]This is hilarious, but it fixed its self [emoji23]
Sent from my iPhone (typie typie)
How did you fix the problem
