Full Version: ListItem.Size BUG and alternatives
This INFO item is not working at all. I've seen many people looking for this with no luck.
So, I'm going to write a script to fetch filesize in videolibrary.xml of skin. but the problem is, I should use runscript to pass filename to my script, like:
RunScript("c:/temp/filesz.py",fname=$INFO[ListItem.FileNameAndPath])
and then script pass back the filesize.
the problem is how to display the filesize in xml?
I should use <onfocus> to run script, but to show the filesize, I'm confused.
No one??
This is very odd problem regarding Kodi, that is asked many times, without any answer till now...
It only works in files mode as far as I'm aware.
(2016-11-02, 10:46)Hitcher Wrote: [ -> ]It only works in files mode as far as I'm aware.
Thanks, do you know how can it be used in video library or somewhere else?
