2016-10-30, 21:41
2016-10-30, 23:55
No, to record you need a proper PVR backend. There are forks of the plugin that records, but in general the answer is no.
2016-10-30, 23:55
(2016-10-30, 23:55)rpcameron Wrote: [ -> ]No, to record you need a proper PVR backend. There are forks of the plugin that records, but in general the answer is no.Which forks?
2016-11-13, 10:36
(2016-10-30, 23:55)ilbarone87 Wrote: [ -> ](2016-10-30, 23:55)rpcameron Wrote: [ -> ]No, to record you need a proper PVR backend. There are forks of the plugin that records, but in general the answer is no.Which forks?
+1 I still didn't found any IPTV Simple Client that can record. Apparently there was one called XTCodes Client but the developer shutted it down..
2016-11-13, 23:34
(2016-11-13, 10:36)titooo Wrote: [ -> ](2016-10-30, 23:55)ilbarone87 Wrote: [ -> ](2016-10-30, 23:55)rpcameron Wrote: [ -> ]No, to record you need a proper PVR backend. There are forks of the plugin that records, but in general the answer is no.Which forks?
this is the iptvsimple client fork that records:
https://github.com/simphax/pvr.iptvsimpl.../recording
it needs to be compiled first for android + windows!
its already been compiled for mac + linux here:
-linux:
https://www.dropbox.com/s/uj1dqgjvzzzysw...2.zip?dl=1
-mac:
http://epg.ninja/clairvoyance/testing/OL...ording.zip
btw i got your pm about xtcodes and will pm you the client tomorow for you to
see if you can do anything. good luck!
but for now, theres nothing for android + windows users!
2016-11-13, 23:36
If I could get a tutorial I could try to compile, but I can't find a deeply detailed one.
2016-11-13, 23:45
does anyone knows how to enable it in apple tv 4 th generation .
becuz i don't see any option of enabling live tv . so the pvr don't load thx
2016-11-14, 01:23
(2016-11-13, 23:45)Japgeisha Wrote: [ -> ]does anyone knows how to enable it in apple tv 4 th generation .
it wont work for apple tv (ios),
its for mac!
it works fine on the right platform.
if you want it for anything els other than linux or mac,
it needs compiling
2016-11-14, 07:42
Thank you that's what I thought
Apple TV 4. Don't have that support. Thx
2016-11-27, 01:33
The source for OSX version of iptvsimple with recording seems to not work.
Would any of you be so kind and share / send me those libraries?
2016-12-02, 10:42
Hi for windows how i compile - Software?
2016-12-13, 22:36
Any update on compiling this for windows?
2016-12-17, 13:17
I tried to compile it for windows but it failed. I wonder if the GitHub repo has all the necessary stuff to get it compiled in windows
