2016-10-31, 00:51
Not sure if anyone else is having this issue...?
But when I first play audio, video or music the volume is very quieter than it should be.
When I change any setting under System, Audio the volume increases and sounds as it should do.
If I stop the video or music and play it again the volume drops again and I have to change a setting again in System, Audio like Send low volume noise as an example.
Audio was fine in beta 1 - 3 but started this issue after beta 4.
Hope this can be fixed in the next update.
