2016-10-31, 17:23
Hi guys
A while ago i updated my second SD Card to Kodi 17. Meanwhile i went through various Libreelec Alpha Builds and also some Milhouse Builds.
On each of these builds i encountered the same problems with iptv simple PVR.
The IPTV content from my local (official and paid) IPTV Provider which is spread using RTP:// Urls, is
- starting playback a lot slower than on Kodi 16 (doesn't matter if channel is first started or switching from one to another channel) and
- producing green artifacts and stuttering sound from time to time
Each channel source looks like: rtp://@999.9.9.9:8888
I already read that there are significant changes going on regarding librtmp but so far i don't really get it ...
Do my problems have something to do with these changes and/or is there anything i could do, to improve RTP:// playback on Kodi 17?
Or should i just wait for the final stable release?
At the moment my RPi2 is running Libreelec Alpha 7.90.007 and the problems i mentioned don't occur on the same Pi with a Kodi 16 microSD.
I'd also like to share codec info of a HD Source from my local IPTV Provider and some logs. Perhaps this helps in some way?
http://imgur.com/a/wxPFC
ffmpeg component specific log: http://pastebin.com/Eiatp2d2 (sry, had to cut a lot because of pastebin's size maximum)
debug log: http://pastebin.com/iMpN01n3
I'd also like to add, that HLS and other sources are running fine, no matter if Kodi 16 (Libreelec 7.0.2) or Kodi 17 (Libreelec 7.90.007/7.90.008)
It's just the RTP Sources on Kodi 17 Builds, which are producing the issues mentioned above. Kodi 16 (Libreelec 7.0.2) playback of the RTP sources from my provider is fine too.
Thank you very much and keep up the great work, greets
