Full Version: Copy SaveGames between XBox's on same LAN.
Dear Member.
I'd like to suggest "new feature" that will fasilitate the transfer of SaveGames between Xbox's on the same LAN.
With Programs/Save Games user can select on selected saveGame either to copy, move or delete it. If user selects Copy/Move a dialog come's up, showing only local partitions.
Can there be FTP/ SMB shares also?
What if Auto XBox regonizion is enabled, can there be automatic transfer possibility under SaveGame options between two XBoxes?
Smile
