2016-11-02, 12:00
Kodi - Latest Beta
Android 6.0 Marshmallow
I have selected to "Allow file renaming and deletion".
I then go through the normal process to remove a video:
Manage > Remove from library > "Do you really want to remove" Yes > "Would you like to delete the selected file" Yes
The video then is removed from my system, until I click [Update Library] > Then it comes back.
I am using an external storage device holding the information. I can access it via FTP and remove the file with no issue, I can also use a file explorer to access a remove the file. But Kodi seems unable to.
