2016-11-03, 02:01
Hello All,
I assume this is the correct forum for basic Linux questions. Actual build is LibreELEC (official) Version: 7.0.2 running Kodi 16.1
Using Kodi to replace Mythtv front end
How would I go about modifying the menu selection from the default? About 80% usage is for OTA recordings running on Mythtv back end. Almost no Live TV is used, just scheduled recordings.
So when I click on TV the default view brings up Channels. I would prefer it going to Recordings. Is this the context menu that I keep hearing about on the left side?
Instead of this order (Channels Guide Recordings Timers Search)
Something like this ( Recordings Channels Guide Timers Search)
I've modified Mythtv menus before with the specific menu/submenu/submenu name.xml and put this in the /home/username mythtv runs under for overrides for things like this. Doesn't break when doing updates etc...
Think Kodi uses advancedsettings.xml . Not sure if that's how things could be modified in Kodi or if there is an addon to take the rocket science out of this.
Any input would be appreciated.
