2016-11-03, 03:20
I have ~/.kodi/temp and ~/.kodi/addons on different file systems. ~/.kodi and ~/.kodi/addons are on the same file system and ~/.kodi/temp is on a different one (I keep temp on a different file system because I don't want to include it my btrfs snapshots).
Both ~/.kodi/[addons,temp] have the same file system permissions:
drwxr-xr-x 1 mythtv users
(I run kodi as the user "mythtv").
Whenever Kodi attempts to update any addon, it fails. Here's an example excerpt from ~/.kodi/temp/kodi.log:
Permissions of "/home/mythtv/.kodi/addons/resource.language.en_us" which the logs say "failed read":
If I su to the "mythtv" user, I can rename, copy, delete, etc the "/home/mythtv/.kodi/addons/resource.language.en_us" directory fine.
Note that Kodi can and does write to ~/.kodi/temp - there are plenty of files and directories in there. If I make ~/.kodi/temp a directory on the same file system as ~/.kodi, then addons upgrade fine. Therefore, I suspect there's a problem with the code that does "copy&delete will be used instead of rename" - but maybe I'm doing something wrong?
I'm using Kodi 17 post beta 5 (git commit c05fc78) built today.
Thanks in advance for the assistance.
21:05:07 T:139855379003136 DEBUG: Unpacking zip://special%3A%2F%2Fhome%2Faddons%2Fpackages%2Fresource.language.en_us-3.0.2.zip/resource.language.en_us/ to /home/mythtv/.kodi/temp/a11290a5-cdd3-4d2d-9681-14102b94326f
21:05:07 T:139855379003136 DEBUG: Rename: Source file "/home/mythtv/.kodi/addons/resource.language.en_us" and target file "/home/mythtv/.kodi/temp/94fb4cac-bfbf-4f54-928e-b0d2ef8c928e" are located on different filesystems, copy&delete will be used instead of rename
21:05:07 T:139855379003136 ERROR: Copy - Failed read from file /home/mythtv/.kodi/addons/resource.language.en_us
21:05:07 T:139855379003136 ERROR: Rename - Error renaming file /home/mythtv/.kodi/addons/resource.language.en_us
21:05:07 T:139855379003136 ERROR: Failed to move old addon files from '/home/mythtv/.kodi/addons/resource.language.en_us' to '/home/mythtv/.kodi/temp/94fb4cac-bfbf-4f54-928e-b0d2ef8c928e'
$ ls -la /home/mythtv/.kodi/addons/resource.language.en_us
total 8
drwxr-xr-x 1 mythtv users 52 Jul 22 19:49 .
drwxr-xr-x 1 mythtv users 7918 Nov 2 00:16 ..
-rw-r--r-- 1 mythtv users 701 Jul 22 19:49 addon.xml
-rw-r--r-- 1 mythtv users 1994 Jul 22 19:49 icon.png
drwxr-xr-x 1 mythtv users 44 Jul 22 19:49 resources
