Hello developers,
I am trying to understand how xbmc works and debugging on the iPhone device but although I am working on a fast device
(iPhone6+), the deployment duration is long and I want to build xbmc source code for iPhonesimulator.
As far as I see from the configure.ac file, there is no a preset configuration for iPhonesimulator, If somebody here made xbmc
build for iPhonesimulator, I will appreciate for a guide to achieve this.
Only MrMC got it to work on his fork and it was a big project to get it work iirc.
(2016-11-03, 08:32)Memphiz Wrote: [ -> ]Only MrMC got it to work on his fork and it was a big project to get it work iirc.
Thanks for the rapid reply,
I think, the fork that You mentioned is
https://github.com/MrMC/mrmc
(If not please let me know)
I've examined it but there is no any configuration for iPhonesimulator
In fact, If xbmc is built on x86 darwin and arm-darwin(ios), then I guess, It should be not a big deal to build for iphonesimulator.
I think MrMC never published the code - don't under estimate our huge number of dependend Libs ... but sure you could proove that this is easy anytime you want
OK, I've done exactly what You say and build only the osx version. I can debug it now, so It's OK for me, thanks.
Memphiz, do you have any opengl experience ? (I am stucked one place,
Below code is run in opengles, therefore It's not existed in osx and I could not debug and could not understand the values of
Yloc, Uloc, and Vloc.)
GLfloat m_tex[3][4][2] = {
{ {{1.0, 2.0}, {2.0, 3.0}}, {{0.0, -3.0}, {9.0, 11.0}}, {{23.0, 12.0}, {43.0, 22.0}}, {{15.0, 4.0}, {3.0, 12.0}} },
{ {{13.0, 4.0}, {56.0, 3.0}}, {{5.0, 9.0}, {3.0, 5.0}}, {{3.0, 1.0}, {4.0, 9.0}}, {{5.0, 4.0}, {7.0, 12.0}} },
{ {{3.0, 9.0}, {6.0, 13.0}}, {{8.0, 19.0}, {13.0, 6.0}}, {{3.0, 3.0}, {9.0, 6.0}}, {{35.0, 7.0}, {13.0, 12.0}} }
glVertexAttribPointer(Yloc, 2, GL_FLOAT, 0, 0, m_tex[0]);
glVertexAttribPointer(Uloc, 2, GL_FLOAT, 0, 0, m_tex[1]);
glVertexAttribPointer(Vloc, 2, GL_FLOAT, 0, 0, m_tex[2]);
I know the meaning of glVertexAttribPointer, It sets the value of m_tex[0] in 2 floats to vertex Yloc but m_tex[0] includes
{{1.0, 2.0}, {2.0, 3.0}}, {{0.0, -3.0}, {9.0, 11.0}}, {{23.0, 12.0}, {43.0, 22.0}}, {{15.0, 4.0}, {3.0, 12.0}} so does it take first two ones ??
{1.0,2.0} I am not sure.
