2016-11-03, 18:02
Bonjour à tous
Voilà un nouveau plugin Arabmovies
Hello
This is a new plugin Arabmovies
Arabmovies
Arabmovies link2
To install the extension:
Download the zip file and save it in a place where you can easily access from your device. Open Kodi. Select System. Select Settings. Select Extension. Select Install from a zip file. Navigate to where you downloaded the zip in the first step and select plugin.video.arabmovies-1.0.1.zip Please wait notification installation.arabmovies is now installed. You can viewed from the extension Videos -> Extensions> arabmovies from your home screen.
Regards
Hello
Arabmovies
Arabmovies link2
Regards
