2016-11-03, 23:27
2016-11-03, 23:27
2016-11-05, 09:19
How did you even get that setting? Only thought you could change cache in advancesettings.xml
Have you read these?Caches Explained
Modify Video Cache
Most people will not need to change these settings.
Modify Video Cache
2016-11-07, 18:46
I don want to open new thread...
I just reinstall Kodi Krypton and I have folder C:\Users\*****\AppData\Roaming\Kodi\
After that I cant update adonns-----"update failed"
I add mannual new folder "temp" and all working.All addon aplay to update.
Is this bug for updating Kodi, i didnt install clean version, just update Kodi V5.
Kodi dont create new folder "temp"automatic when install.
I think that newest version have same bug
http://forum.kodi.tv/showthread.php?tid=...pid2452185
2016-11-07, 18:55
I have that as well Angelinas with Beta5, all updates fail to install or update due to 'temp' folder missing.
Don't know if it is by accident or not?
2016-11-07, 18:59
Tnx Mike
I didnt alone...that is bug, with manual solution just add new folder "temp".
Team , Answer please,this is old bug
2016-11-07, 21:39
