Full Version: xbmc.notification help
Could someone throw some light on the two params of time and image when used with xbmc.notification()
time: I've been informed it should be milliseconds, but ieven if I pass 140000 (14secs) it shows for the default time (~3secs)
example command used:
xbmc.executebuiltin("XBMC.Notification('heading','message',time=14000)")
image: Always attempts to load filename from the current skins media folder.
ERROR: Texture manager unable to load file: Q:\skin\Project Mayhem III\media\image=Q:\scripts\myscriptname\resources\notify.gif
xbmc.executebuiltin("XBMC.Notification('heading','message',image='Q:\scripts\myscriptname\resources\notify.gif')")
Is it possible to get it to load an image from your own scripts path?
Is there a preferred image type/size ?
i dont think you need to put time= ... just the value for notifcations.
("Title","Message","14000","q:\\userdata\\thumbnails\\icons\\imanicon.gif")
Cannot recall if it uses "" though but the above i think would work.
That sorted the time (quotes not needed btw). thanks.
but image still gives the error
ERROR: Texture manager unable to load file: Q:\skin\Project Mayhem III\media\"q:\userdata\thumbnails\icons\notify.gif"
Its seems to be hardcoded to join whatevers passed onto current skin path?
Here is a simple solution, it only works in PM3 though, i've tested PM3 and MC360.
import xbmc, xbmcgui
import os
imgPath = os.path.join(os.getcwd().replace(';',''), 'resources').lstrip("Q:\\")
imgFile = imgPath + "\\preview.png"
xbmc.executebuiltin('XBMC.Notification(heading,message,5000,..\\..\\..\\' + imgFile + ')')
Thanks for having a look at it. but tbh, as its only a PMIII solution, its not ideal.
Ideally, XBMC.Notification() could check in the path given before looking for filename in the skin path.
