2016-11-06, 15:20
Hi guys, this problem been present since estuary introduction.
Sometimes when you start kodi, skin wont highlight any item or category by default. So, when you try to move with keyboard or control pad, you will hear the ui clicks but nothing will happen.
You will need to use the mouse to highlight some homescreen category and then you can move with keyboard, control pad or whatever.
So, problem is estuary not setting a default highlight item when kodi start.
I think It could be solved changing skin to highlight the first category item (ie MOVIES) by default when kodi start.
