Full Version: Any way to show DD, DTS, h264, aspect ratio, etc?
Hi guys, when using confluence, and browsing movie library, it will show what type of audio and video is using the movie.
It just show the correponding logos below the movie art.
You can see an example here: https://i.imgur.com/YdAf1y8.png
That feature was handy when you have the same movie with different video/audio encoding.
Didnt see any option to turn this on on estuary.
There is a way? In case it does not, will be added in the future?
Still there with estuary:
BUT it is set to OFF by default so be sure that this is set to ON
Hi, thanks, that worked.
It s not as fancy or good looking like on confluence, but do the job.
You can also use estuary MOD
Logos are a bit better:
