Full Version: SkyTG24 plugin raise an error
Hello, is my first post here and I would like to fix a plugin that doesn't work.
I tried to use the plugin SkyTG24 but python raise the AttributeError exception because the xmb.PLAYER_CORE_MPLAYER is not available.
The code of the plugin is pretty simple and is in github: https://github.com/NeverWise/plugin.vide...default.py
The line:
xbmc.Player(xbmc.PLAYER_CORE_MPLAYER).play('rtmp://cp49989.live.edgefcs.net:1935/live/streamRM1@2564 live=true', li)
should be changed with a compatible line. I can do that, but where I can find the docs to update the plugin to the newest kodi version?
Thank you
I'm getting the same error here, who should fix this plugin?
send the plugin author a fix via PR on github and ask him to update the plugin in our repo.
If he doesn't respond after a while, you could directly send the fix to us
