Full Version: cast list in any window/episodes numbers/forced subtitles
hello...
for my skin, here are my 3 problems :
CAST :
i guess Cast list for tvshow, movie,etc... is already in kodi database....but we can only get it in dialogvideoinfo and container(50)....
Is there any possibility to get cast list , including pictures, outside of Dialogvideoinfo ?
Actually, the only solution i get is to call this in a list container :
<content target="videos">plugin://script.skin.helper.service/?action=getcast&amp;tvshow=$INFO[ListItem.DBID]</content>
i think to do it by another addon is non sense if all informations are already in database....
EPISODES :
using thetvdb addon, i don't find a solution to get the total number of tvshow episodes......
Usefull for showing how many episodes are missing until the season end....
SUBTITLES :
ListItem.SubtitleLanguage provide language of subtitle, but the is no difference with Forced and not......
So, in movie, i get many subtitles flags with the same language except one is for all dialog and one is for forced .....
example :
Quote:Texte #1
Format : UTF-8
Identifiant du codec : S_TEXT/UTF8
Identifiant du codec/Info : UTF-8 Plain Text
Durée : 59mn 43s
Débit : 0 bps
Count of elements : 12
Taille du flux : 203 Octets (0%)
Titre : FR FORCED
Langue : Français
Default : Oui
Forced : Oui
Texte #2
Format : UTF-8
Durée : 1h 50mn
Débit : 52 bps
Count of elements : 1373
Taille du flux : 42,2 Kio (0%)
Titre : FULL FR
Langue : Français
Default : Non
Forced : Non
But under KODI, ListItem.Property(SubtitleLanguage.1) is Fre
and ListItem.Property(SubtitleLanguage.2) is Fre
Can't really check fo Forced flag ?
Thank Wink
Not possible -
(2011-03-30, 19:27)spiff Wrote: [ -> ]problem is it requires many extra queries which slows down the listing tons...
He siad he don't want to use skin helper for the cast thinks its nonsense using a addon.
I don't get what the issue is.
Sorry for that, but the non sense is that kodi database hasvideodb://movies/sets//movies/sets/ant to use but for use it i must use an external program…. (Script)
I found solution for movieset, songs and albums, to avoid calling skinhelper to get detail… .
Skinhelper is great but sometimes seem to lag… .
May be fast if we can access directly to database like with videodb: //… .. ,with content tag…
Anyway, it appear skinhelper is the only solution to get casting outside of dialogvideinfo… .
Once cached skin helper is fine.
You will get same initial lag as kodi cacheing first run.
And sorry for previous nonsense! Big Grin
in those views , i get more fast result,than skinhelper, to get movies inside movieset with
<content sortby="year" sortorder="ascending">videodb://movies/sets/$INFO[ListItem.DBID]</content>
and here with in artists view to get artists albums details :
<content>musicdb://artists/$INFO[ListItem.DBID]</content>
that's why i don't understand why we can't do same with cast.......
