Hello:
When I enter kodi krypton the first time, I do not see the music submenu:
http://prnt.sc/d640lc
Then I enter: videos
I go to the main menu and load the music submenu:
http://prnt.sc/d64165
Is this a bug? Or how can I fix it?
I use kodi krypton 17 beta 5 on windows 7
Your image posts are not showing up for me, could be a skin issue.
Firt time open kodi:
I enter and exit from menu videos:
Thank you
If the default skin works well, then it definitely is a skin issue (looks like the old confluence skin?)
Add-on:Confluence (wiki) I don't think this is a windows issue. If it's alright with you, your post might be better responded in this forum
http://forum.kodi.tv/forumdisplay.php?fid=125 and if you wish, I'll move it over?
bom eu já vi no site da windons que o beta é feito pra windons 10
As I've told you before on that point. If you keep ignoring that simple rule then action will be taken.
I was doing some upgrade testing on my skin mod, and realized my Kodi Jarvis music menus were non-functioning in the Krypton upgrade. The reason was that the actions on clicking the menu buttons (saved in the Jarvis skin settings file and still used in Krypton) were assigned to some version of opening the "musiclibrary" window, which no longer exists in Krypton (now it's just "music"). I don't know that that is what is going on here, but something to consider in general when upgrading to Krypton.
scott s.
(2016-11-12, 23:24)PatK Wrote: [ -> ]If the default skin works well, then it definitely is a skin issue (looks like the old confluence skin?) Add-on:Confluence (wiki) I don't think this is a windows issue. If it's alright with you, your post might be better responded in this forum http://forum.kodi.tv/forumdisplay.php?fid=125 and if you wish, I'll move it over?
Sorry for the delay please move it.
Thank you.
