2016-11-13, 21:05
Suppose you have multiple skins (I've about 7) and you setup each skin the way you want (specifically the view types - ie. for Movies you might have a poster view, for TV shows a banner view, for episodes a list view for skin1, then for skin2 you might have a different setup etc). I find that if I change skins, the previously set up views are almost always 'lost' and I have to set them up again.
This happens consistently. I was assuming the 'addon_data' folder would hold this information per skin so that the views I have setup for each skin would always be remembered if I switched skins.
Is this a kodi bug, a bug with the way the skin is coded, or is there a setting somewhere within kodi (an advanced setting perhaps) to prevent this from happening??
Many thanks for any info!
