Full Version: Add color tags on the remote app.
Hi, before I start I did a search for "color", only a old thread with no replies complaining about it came up.
So I use the remote app for switching channels for Live TV. Since a lot of addons/playlists use the [color] tags, the channel list on the remote app is usually unreadable with a bunch of color tags. It would be nice if the app can accomidate for the color tags and use them on the remote app to actually color the text since its kinda harder to see what the channels list is.
Here is my example to show:
rather than use the tag I will try to take it away, otherwise you would not see anything with white background and white lettering
(2016-11-14, 10:56)joethefox Wrote: [ -> ]rather than use the tag I will try to take it away, otherwise you would not see anything with white background and white lettering
Oh yeah, just noticed my example had white color codes. In that case, yeah, find a way to remove the tags then,
