Hello,
I bought a remote control as below (for RPi 3):
https://ae01.alicdn.com/kf/HTB1fLR_NFXXX...XFXXX5.jpg
Unfortunately, not all buttons are functional (e.g. shut down, volume up/down, etc.).
I tried to use the
Keymap Editor. However, not all buttons are recognized by the editor - I can't assign functions to them.
How can I fix it?
Which OS are you using? LibreELEC? OSMC? Raspbian?
You can see my sample file which i have made for Vigica 2.4 remote.
http://forum.kodi.tv/showthread.php?tid=220378
You can use it for reference file. To get the codes I have used debugging in Kodi and pressed the button then have checked in the debug log to get the code.
Is airmouse working on this remote or. do you have to press buttons to move the mouse cursor?
(2016-11-15, 03:50)Ned Scott Wrote: [ -> ]Which OS are you using? LibreELEC? OSMC? Raspbian?
Osmc. On Xbian was the same problem.
(2016-11-15, 07:05)illiac4 Wrote: [ -> ]You can see my sample file which i have made for Vigica 2.4 remote. http://forum.kodi.tv/showthread.php?tid=220378
Hello again,
illiac4, I used your keymaps for VIgica, but not all buttons were recognized (e.g. for volume)
Mouse cursor is working correctl (from the beginning).
