hi,i'm not trying to hijack your thread,i'm watching it for solution.i'veinstalled,uninstalled twice,then ending 3rd try i found
banned add-on (wiki) reference removed and realized what is was for.i just uninstalled and tried another setup.the wiki is poorly written.i found better instructions at
banned site reference removed .i also tried a free telly thing,basically puttogether
.out of all this effort i still get this result.
great sound,subtitles.i thought i might need video card.
but the above poster has one and still has this problem,so i'll save my money ,keep trolling for similar problems,and keep trying .if i fix it i'll let you know.
btw win7 ultimate64x but i just did 86.....i could try compatability mode AND i found someone said go to appdata/roaming and delete.xml gui in user data,and it didnt hurt,but didnt help
also i tried disabling AERO ON WIN 7>CUSTOMIZE
OMG.I GOT VIDEO !!.THANK YOU.SOO MUCH.last things i did was unhide hidden folders in windows then C:/user/pcname/appdata/roaming/kodi/userdata/guisettings.xml(i deleted it but left in trash to restore if needed)
tthen i did ur blue dot above(VIDEO ACCELERATION,I TURNED IT OFF AND CHANGED IT FROM AUTO TO SOFTWARE.HAD TO ADJUST SETTINGS LEVEL--basic,standard,ADVANCED AND EXPERT HAVE ACCELERATION SETTINGS ON VIDEO
.....BTW kodi made new .xml so ones in trash can delete.
.I'VE been trying to wrap my brain around this for 1 1/2 yrs for my 73&79 yr old parents.$80 a month for 1 soap opera and lifetime and hallmark movies.so happy they made this for windows.old pcs i have lots of.MERRY CHRISTMAS ALL
