Full Version: Phenomenal Skin - mod
Pages: 1 2
Thank you for the skin, it is becoming one of my favorites. I like Titan but the beta keeps crashing.
Some things I had trouble with.
The addons, and services have been changing over the last couple of days. Some addons needed updating.
The Kodi repository loads, and all works in Kodi v17.
Kodi v16 has problems with "script.image.resource.select" and python dependencies. This means you can't change backgrounds.
The backup/restore skin feature doesn't work.
The skins you offer on the forum only work with v16, unless you replace addon.xml used in v17.
The last skin posted won't let me change the backgrounds. The default colors in your beta are awful Smile I do enjoy changing to my liking.
I am enjoying your skin. Thank you
trying to download the skin , when i do i get a file "amigo_bundle.exe" ?? cant unzip it on windows PC and when i try to run it nothing happens ? I had this skin previously by downloading it and extracting folders ? is this link wrong now ?
for kodi 17
Not yet done everything
video
https://youtu.be/E10wXvPpsKM
download
30.03.2017
http://www.fayloobmennik.net/6924591
Many changes, bugfixes
1.04.2017
video
https://youtu.be/Sc89cTwXSSw
download
http://www.fayloobmennik.net/6928926
Thanks for your hard work, vadim72
For those of you having issues, I thought I would detail what I have found.
You must have the titan beta distro, and be certain your dependencies are up to date. There are still some bugs in those plug-ins, so keep them up to date.
Downloading the file, click on "Скачать" it will show in about 10 seconds.
The file downloaded is packaged wrong, and won't install.
Extract the folder, skin.phenomenal from the zip file. Then zip it as skin.phenomenal.zip, you can load it from "addons from zip file"
Be careful sometimes there are two skin.phenomenal folders nested.
Backup/Restore skin doesn't work for me. I have no idea were the backup file is saved.
Vad's color theme is too bright for me. So I go to DESIGN - Theme Color - and select the 3rd blue all the way to the left. Save
Backround packs - I pick clear design - Apply - Backgrouds - yes - yes.
After that I give up, for now.
I'm going to work on a dark blue theme. I would like to be able to change Vad's backgrounds. I want simple backgrounds, lots of fan art, the detail icons to have color too.
The right to left thing can be confusing, but I am adjusting.
Again, thanks for the skin!!
(2017-04-02, 19:20)Laserray Wrote: [ -> ]Thanks for your hard work, vadim72
This is not an installation
I know about many mistakes, there will be a fix version, and in manual mode, scatter on folders
This is a rough draft,
The background color can be replaced most, the rest I will correct
Now, it works adding a new category to the main menu
Further
There are still corrections
I need to put this script.skinshortcuts, I put it in the archive, it needs to be installed
Here is a video of the addition of a category and a widget in the main menu of the skin
Https://youtu.be/25BNXoRaogI
Download, and scatter on folders
http://www.fayloobmennik.net/6931309
Any plans for a Kodi 18 Release of this Phenomenal work? bahahahaha see what I did there?
Pages: 1 2
