Full Version: Extended Info Mod
When I bring up the menu on a movie etc & click information you get the synopsis, however for some reason sometimes it says to download extended info mod? Why is this?
Also, with extended info mod installed it will not show actors/cast images?
Which version of Mimic are you using?
(2016-11-18, 16:31)braz Wrote: [ -> ]Which version of Mimic are you using?
3.4.1
ExtendedInfo is used to display the actor list and the Youtube videos tab. If Extendedinfo is not installed, it falls back to the default actor list. I just tested uninstalling Extendedinfo, and I'm still getting the cast list on my machine.
Not sure what the issue is or if there is a way to prevent it from prompting you to install Extendedinfo. It's been a long time since I've used Jarvis.
Same here... Anybody have an idea to resolve the problem?
