WOOOW thats very nice m8,one question will it be available for 4:3?
very sexy though
Screenshots appear to be 4:3.
shizzle Wrote:WOOOW thats very nice m8,one question will it be available for 4:3?
very sexy though
i currently don't have a widescreen TV (yet..!), so the initial version WILL be 4:3. when the widescreen tv rolls around, then it will be both 4:3 and 16:9!
glad you like it! more reason to skin it.
FYI; it is recommended that you if you own a Windows PC to use the
XBMC_PC for Win32 build under Windows for skin development (just google "T3CH XBMC" for a pre-compiled copy), or if you are Linux user then use
XBMC for Linux. These will among other things let you test 4:3 and 16:9 aspect ratios as well as high definition (720p and 1080i/1080p) even if you do not own a such TV.
And another advantage is not having to ftp the edited files to your xbox everytime you make changes
SyphOn Wrote:And another advantage is not having to ftp the edited files to your xbox everytime you make changes
Super Indeed the no1 reason to use them
ALso note that the linux version is not always fully up to date with skinning features but is useally at most a week or so behind
thanks for the advice, and i would use it...the only problem is: i'm on a mac. i'm actually looking into buying a windowsXP CD so I can use it with BootCamp...the FTP thing is already getting REALLY old...haha
