Full Version: ShadowTeks Madnox Mods (Krypton)
Here I will be adding my Madnox - Krypton mods, I'll add any previous mods that still work (like graphical mods) and all new ones..
To start...
hernandito's Backdrops with ShadowTeks Additions - Update Nov 18
100's of new background images made for Madnox, click link above for thread and downloads!
Also, this graphical mod still works fine to my knowledge, if any image is missing, let me know:
Re-Colored Default Icons
Link to all the .XBT Files (all colors):
Link to all loose separate image files (all colors):
Instructions:
For the .xbt download, copy them to your media folder, then just choose the theme you wish to use.
For the loose files (if you don't have/use a textures.xbt file) backup your default icons first, then copy the color you want and overwrite the default ones.
Info Wall Mod
Info Wall (Addon Wall) Larger fanart and Logo..
Here is my personal Infowall I use (aka addon wall) It is designed to use with no top bar on top (you can turn off in settings) and NO background panel. Also I personally think its better to use with NO fanart or extrafanart enabled.. simply pick a single image. But that's just my opinion. After all the fanart box in the view will scroll through all extrafanart...anyway
It has a new frame for fanart (purple) and a mini frame for tv episodes (grey/black).. also the letterbox alphabet letter chooser (or whatever its called lol) has been adjusted accordingly
Below images are shown when you hover mouse over area with the letterbox selector.
Movies:
TV Episodes:
Text location raise a bit for episode name and changed the text color to reflect the color of text you pick for view rather then the color background you picked.
as noted above, image below show when you hover over letter picker.. Episode image frame for all episodes added.. episode text info changed to orange (cause I like it and easier to see) easy to change, just search for orange and change to what you want.
Back up your files first!!!
My Recolored background I made from the red one:
Reserved
Reserved
Reserved
Reserved
Reserved
This should do it..
Reserved..
