Full Version: [RELEASE] Empty - a very basic XBMC skin for beginners to start learn skinning from
Pages: 1 2 3
Hitcher Wrote:I'd recommend using Confluence as well.
Also, make sure you get the XML plugin for Notepad++ as it's very handy for error checking and lining everything up tidily.
xmltools_2.3.1_r805_unicode_beta2.zip
and -
ext_libs.zip
ext_libs.zip has no unicode support, so the xmltools doesn't want to work together
Pages: 1 2 3
