Full Version: Use/control Harmony Hub with Kodi?
I was wondering if it would be possible to control your Harmony Hub from within Kodi and if someone managed to do so already?
My idea was to map the sound related keys in my keymap.xml to some sort of script/addon to control volume actions like volume up/down and mute.
This way i could easily control my audio from every app that is using the Kodi functions only like for example Yatse or simply the Kodi webinterface.
There are situations that i don't have quick access to the original remote or to lazy to switch between apps to control volume or i wanted to have bigger volume increase/decrease steps. So i was thinking about this possibility.
I found some scripts that would make this possible:
https://pypi.python.org/pypi/pyharmony
https://github.com/swissmanu/harmonyhubjs-client
I was hoping someone already managed to create something that does the above before i start trying to create something.
This question is best posted in hardware Peripherals
[PatK Moving thread] http://forum.kodi.tv/forumdisplay.php?fid=254
