Unjailbroken ipad mini 2
ios 10.1.1
Kodi v16 & v17b5
It stops playing video every 5 mins automatically, then u have to press play again then it will continue playing.
But when it comes to play live TV, everything is OK, no 5-min-autostops.
This never happens before.
What could be the bug here? Can
please post a full
debug log (wiki) to pastebin.com or a similar site and link here
You don't play anything in those logs...
(2016-11-22, 08:27)Memphiz Wrote: [ -> ]You don't play anything in those logs...
I tried to play video three times, but when it comes to 5 mins, now kodi just crashed and quit. It is supposed to have a crash log, I think. But every time when i try to upload the log, it says no crash log found now.
Finally, upload another log. Please check.
https://paste.ubuntu.com/23515911/
This is a log when I tried to play 2.Broke.Girls.S06E08.720p.HDTV.X264-DIMENSION.mkv.
Here is the log:
https://paste.ubuntu.com/23516618/
I continued to play 2.Broke.Girls.S06E08.720p.HDTV.X264-DIMENSION.mkv at 20:22, then it stopped @20:26, only played for about 4m40s.
I need you to do a new log. Please disable all component specific logging in the debug menu and also disable the enigma addon for your test. The size of the logfile exceeds the time i am willing to spend for reading it.
(2016-11-22, 19:28)Memphiz Wrote: [ -> ]I need you to do a new log. Please disable all component specific logging in the debug menu and also disable the enigma addon for your test. The size of the logfile exceeds the time i am willing to spend for reading it.
Hi, here is a new log, disabling the specific logging and engima addon:
https://paste.ubuntu.com/23519459/
I played twice the video: first time starting @6:46 and stopping @6:52, second time starting @7:01 and stopping&quitting @7:06.
Thank you for the help!
Playback stops because the video can't be read anymore. Alot of read errors and then playback stops. Is your samba server / nas setup to suspend disks or something like that after 5 minutes? The cause is somewhere in the direction of wifi or server...
(2016-11-23, 08:28)Memphiz Wrote: [ -> ]Playback stops because the video can't be read anymore. Alot of read errors and then playback stops. Is your samba server / nas setup to suspend disks or something like that after 5 minutes? The cause is somewhere in the direction of wifi or server...
Turned off the auto-suspend disk, but still stop playing every 5 mins as usual.
BTW, if it is a problem of my samba server, there should be the same problem reproduced on other devices when playing the videos from it. But I tried to use the kodi for mac, everything goes well, no 5-min stops.
I can only tell you what the log tells me
it has read errors ...
(2016-11-23, 17:00)Memphiz Wrote: [ -> ]I can only tell you what the log tells me it has read errors ...
Thanks! Trying to find out what could cause the read errors... cuz this problem never happened before on iPad before and never on other Kodi...
Nearly Same Setup (iPad mini 1, iOS 9.3.5, Kodi 17b6) and same problem here. No problems on other machines. Just the iOS version stops every 5 minutes. Isnt wifi kept alive?
