Is there a guide on how to configure Kodi to use Schedules Direct for the EPG guide. I am thinking of paying for the Schedules Direct service if I can get it to work with Kodi.
That depends on what pvr backend you decide to use. You will either have to generate an xmltv.xml file or plug your credentials into the backend.
Sent from my Nexus 6
yes - need more info though on the source of the
PVR (wiki) and which backend you will be using. Ex: I use my hdhomerun prime in multiple ways within kodi.
PseudoTV Live, TV Guide, IPTV Simple, HDHomerun Add-on
As I understand it, this particular PVR client cannot make use of external guide sources.
