Full Version: New movies stopped showing up (but scanned into db)
Hello,
Recently my newly added movies stopped showing up in the Movies view. Movies by title, by year, new movies, etc, none is working. I checked the db export, the files are scanned into the db, complete with data (fanart, plot, cast, etc). If I search for the movie title from the side menu, the movie is found and can be played. It also shows up in a custom playlist (widget on main screen).
The last 2 movies are missing (Locke, Project Almanac).
This is the db export: http://paste.ubuntu.com/23524401/
This is a log during a movie scan (does nothing as the movie has already been scanned): http://paste.ubuntu.com/23524310
This is the custom playlist which DOES show the film: http://paste.ubuntu.com/23524415/
This is not a skin issue, tried Confluence and other skins, same result.
Any help is appreciated.
Are these the only two movies missing? If so change their file names substantially. Run clean database then reboot and scan them back in, see if they show then. This has worked for me in the past.
I do not think you will get much help here,
You should read 119117 (thread)
you log contains a No No Repo
Thank You
Thanks kimkl,
Do you mean that having Chrome Launcher plugin from superrepo is the reason for not getting help? That is the only plugin not from the kodi repo (that I am aware of, anyway). I don't know of any piracy plugins in my setup, please let me know if you see something wrong,
Thank you
(2016-11-24, 01:59)sy278 Wrote: [ -> ]Are these the only two movies missing? If so change their file names substantially. Run clean database then reboot and scan them back in, see if they show then. This has worked for me in the past.
I did this, did not help.
I changed the name completely, purged then rescanned the media db. From the log I can see that the scraper found the movie and added info to the db. Still not showing up.
I read your reply, and i say this in the best possible way, read the banned list the forum rules, as they contain information about what may be discussed and what not. on the Forum
And also states which add-on and Repo you should not use if you wish the "TK" to help.
But i hope you get your problem fixed m8.Big Grin
I am off, later m8
Thank You
