2016-11-24, 00:07
I am using Kodi 17 Beta 5 running on Window 10; I use Confluence theme and have 'Group Items' enabled in the TV Recordings; Backend server is ArgusTV 2.3.
The recording list includes a group for the show 'Have you been paying attention?' but when I enter the list to see the shows, I see only two entries, the normal '..' entry at the top of the list and then a second '..' underneath (but none of the shows appear).
If I disable 'Group Items', the recordings all show normally and will play.
This is working as expected on a second Kodi instance running 16.1 on the same box.
I assume a pattern matching / regex issue in the grouping code but I am not in a position to debug this. Happy to do test fixes if required.
Thanks,
Graham
Thanks,
Graham
