Hello
I installed tvheadend 4.2 build "service.tvheadend42-8.1.107-#1122-milhouse-v4.1..>" from
http://milhouse.libreelec.tv/builds/addo...2/?C=M&O=D
and found that liben50221 is not enabled in those builds: "dvben50221 no" (in about, details )
I would suggest to enable it, since this option allows the use of hw cam 's like the one in TT S2 3650 CI I'm using.
HW CAM is working perfect with VDR, and in the tvheadend forums is noted that if compiled with this option it should work too...
I'm not sure I've this is the right thread to post to, since I also posted this to libreelec forum too, but got no answer...
Thanks a lot
Ognian
Ognian en50221 has been disabled as there was a problem some time ago (nobody really remembers what exactly) and as it couldn't be tested it was felt best to disable it.
I've uploaded a version of the addon, #1126x for
RPi2 which has en50221 enabled - perhaps you can test it and report any issues.
Ping @
Ognian - please respond or forget it...
Sorry for the delay, somehow email notifications where turned off... (I turned them on now)
although --enable-dvben50221 is set now, scrolling further down in the about dialog shows:
dvben50221 no
looks like something went wrong during compilation; I found a hint that dvb_apps should be installed, but I'm not sure if this is during compile time or at run time.
I'll test further...
What actually should happen is that a CAM checkbox appears in the adapter settings...
Milhouse sorry for the late answer, are you still following this thread?
Ah yes, sorry distracted by some unrelated Kodi 18 build issues. Will need to discuss this with the team members to see what this dvb-apps dependency is all about. I'll update this thread when I have more news.
thanks
tested the above version, but it did not start:
/storage/.kodi/userdata/addon_data/service.tvheadend42/service.log
/storage/.kodi/addons/service.tvheadend42/bin/tvheadend: line 1: can't create ^Ap.^]@..n^C@8: Read-only file system
/storage/.kodi/addons/service.tvheadend42/bin/tvheadend: line 1: ^?ELF^B^A^A^C: not found
/storage/.kodi/addons/service.tvheadend42/bin/tvheadend: line 2: syntax error: unexpected ")"
what am I doing wrong?
could it be that this is not for the rpi2?
OK, much better. Actually it works, but no passthru and channel switching is not reliable ...
Maybe thats because I tested with Kodi 18 alpha...
Actually I will try a new install now, but I'm not sure which libreelec version to take.
Any recommendations ?
Ok, now I'm on libreelec 7.90.009 and everything looks good :-)
So will this version be "rolled" out into the libreelec repo? Do you have a time estimate?
I will still test a little bit more and report here...
For me this version is the first usable one, since I wouldn't be able to view even free channels since a CI "MUST" be at least properly initialised to not "disturb" free channels...
I still have one other problem to solve before this gets my default tv, I have a rotor and as long as the rotor is between the receiver and the dish I can't receive anything, but this is for a different thread...
Due the fact that nobody from us had such an hardware we have to rely at users that report
Tx will include it at next update (~1week).
