2016-11-25, 10:59
I'm running Jarvis on Windows 7 but this happens on Android as well. Mainly tested on confluence theme but have seen this issue with Aeon MQ as well. When profiles are enabled and you have at least two profiles. Master user and UserA. Turn on login screen. Launch Kodi and pick Master user then go into "TV Shows". It will work fine. Now logout Master user and login to UserA and go into "TV Shows". Instead of going straight into "TV Shows" it goes into Videos > Library view. Once you back out to main menu (staying logged in as UserA) and go back in to TV Shows it works fine after that. That is until you switch users again and then the issue repeats. Issue also impacts Movies as well. Below is debug log excerpt. Any thoughts?
Bad:
01:36:31 T:7388 DEBUG: Activating window ID: 10025
01:36:32 T:7388 DEBUG: ------ Window Deinit (Home.xml) ------
01:36:32 T:7388 DEBUG: ------ Window Init (MyVideoNav.xml) ------
01:36:32 T:7388 INFO: Loading skin file: MyVideoNav.xml, load type: KEEP_IN_MEMORY
01:36:32 T:7388 DEBUG: CGUIMediaWindow::GetDirectory ()
01:36:32 T:7388 DEBUG: ParentPath = [videodb://tvshows/titles/]
01:36:32 T:2132 DEBUG: Thread BackgroundLoader start, auto delete: false
01:36:32 T:2132 DEBUG: Thread BackgroundLoader 2132 terminating
01:36:33 T:7388 DEBUG: CWinEventsWin32::WndProcWindow is active
Good:
01:37:31 T:7388 DEBUG: Activating window ID: 10025
01:37:32 T:7388 DEBUG: ------ Window Deinit (Home.xml) ------
01:37:32 T:7388 DEBUG: ------ Window Init (MyVideoNav.xml) ------
01:37:32 T:7388 DEBUG: CGUIMediaWindow::GetDirectory (videodb://tvshows/titles/)
01:37:32 T:7388 DEBUG: ParentPath = [videodb://tvshows/titles/]
01:37:32 T:7388 DEBUG: CVideoDatabase::RunQuery took 4 ms for 145 items query: SELECT * FROM tvshow_view
01:37:32 T:10748 DEBUG: Thread BackgroundLoader start, auto delete: false
01:37:32 T:7216 DEBUG: Thread JobWorker start, auto delete: true
01:37:32 T:10748 DEBUG: Thread BackgroundLoader 10748 terminating
01:37:32 T:1676 DEBUG: Thread JobWorker start, auto delete: true
01:37:32 T:7388 DEBUG: ------ Window Init (Pointer.xml) ------
01:37:33 T:7388 DEBUG: CWinEventsWin32::WndProcWindow is active
PS - I know it's not a huge issue but it gets annoying when you have 4 or 5 different profiles for each family member and always have to back out and go back in after logging in.
Bad:
Good:
