So my problem is simple (I guess), Kodi won't show my PC's files when I try to browse. It does show a workgroup, and a Kodibuntu folder is there, but i can't seem to fint my movies and music.
If anyone could help, that would be appreciated.
Have you shared the folder they are in?
(2016-11-26, 06:20)nickr Wrote: [ -> ]Have you shared the folder they are in?
I have shared my Music and Movies folders, yes.
(2016-11-26, 14:35)delijanos Wrote: [ -> ] (2016-11-26, 06:20)nickr Wrote: [ -> ]Have you shared the folder they are in?
Well, I have made some progress, my PC does show up in the Workgroup, but when I try to access it it says 'Operation not permitted.'
I am really hoping to access my files through my HTPC, so if anyone could help me I would really, really appreciate it.
What os is the server using? What os is the kodi machine using?
(2016-11-27, 03:44)nickr Wrote: [ -> ]What os is the server using? What os is the kodi machine using?
I've shared my files on my Win 10 PC and am trying to access it via a machine that I installed Kodibuntu on, and updated it to Ubuntu 16.
OK make sure you are using proper SMB on the win10 machine, not "homegroup" or whatever it is called.
