Hi, I'm using KODI 16.1 and when I click pause my ODS doesn't look like the screenshot here :
http://kodi.wiki/images/thumb/1/10/OSD.v...e_zoom.png
But like a mini version of it, with only the time and a pause button (So I can't access the subtitles button for example.) How to configure the OSD to be in full mode ?
What are you using to control it - the answer may depend on that?
(2016-11-26, 21:19)franck Wrote: [ -> ]Hi, I'm using KODI 16.1 and when I click pause my ODS doesn't look like the screenshot here : http://kodi.wiki/images/thumb/1/10/OSD.v...e_zoom.png
Are you using the default skin, Confluence?
(2016-11-27, 12:54)Ned Scott Wrote: [ -> ] (2016-11-26, 21:19)franck Wrote: [ -> ]Hi, I'm using KODI 16.1 and when I click pause my ODS doesn't look like the screenshot here : http://kodi.wiki/images/thumb/1/10/OSD.v...e_zoom.png
Yes, I'm using the default skin, this is what I see when I press "pause"
That's normal, that's just the status/seeking display. You need to press enter/return/select/ok to get the OSD.
(2016-11-27, 13:06)Ned Scott Wrote: [ -> ]That's normal, that's just the status/seeking display. You need to press enter/return/select/ok to get the OSD.
Interesting, the thing is: I'm controlling Kodi with an iBUFFALO "Classic USB Gamepad", and this is the result I get when I press "start" on it. None of the pad buttons is getting me to the OSD...
Which OS are you using? LibreELEC, OSMC, Xbian, plain Raspbian?
(2016-11-27, 13:18)Ned Scott Wrote: [ -> ]Which OS are you using? LibreELEC, OSMC, Xbian, plain Raspbian?
Raspbian
I think the A button should do it. If not, edit your keymap file.
Thanks for the input, where do I find the default xmls ?
I copied the joystick.xml and gamepad.xml files from
https://github.com/xbmc/xbmc/tree/16.1rc...is/system/ to my .kodi/userdata/keymaps directory without noticing any change.
In kodi.log it refers to my gamepad as "joystick" so i'm not sure which one matters...
21:24:46 25.798468 T:1944207936 NOTICE: Found a joystick : use it as a joystick input device - /dev/input/event0
21:24:46 25.833912 T:1944207936 NOTICE: Found a joystick : use it as a joystick input device - /dev/input/event1
Also OSD is already mentioned for the start button, <FullscreenVideo><gamepad> of gamepad.xml, but it still gives me the status/seeking display when I click it...
I'll flash an mSD card with Raspbian and test with my iBuffalo controller. I think there were some controller issues with vanilla Raspbian builds.
Raspbian doesn't have issues with controllers, at least not more than other linux systems.
Kodi doesn't have joystick support on the Raspberry Pi. Only Kodi 17 will have, but is still in beta.
franck is mostly likely using RetroPie's Kodi version, 16.1 which has unoficial experimental joystick support. He just needs to read the wiki's and change his keymap accordingly.
