Hello, the widget at the top with genre, year and list by recentlyadded for example seems very hard to modify if you want it based on a smart playlist.
This was doable on the first estuary edition, any tips on how I can change those shortcuts?
best regards
marantz
for example
<code>
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<node order="10" type="folder" visible="Library.HasContent(Movies)">
<label>20386</label>
<icon>DefaultRecentlyAddedMovies.png</icon>
<path>videodb://recentlyaddedmovies/</path>
</node>
</code>
how can I make that use a smart playlist?
There are two things you can do. firstly, turn your smartplaylist into a video node because video nodes and smartplaylist use the same rules. secondly, youi can do as you want and link a video node to your already made by:
<?xml version='1.0' encoding='UTF-8'?>
<node order="1" type="filter">
<label>name of node</label>
<content>movies</content>
<icon>the icon you want to show up</icon>
<rule field="playlist" operator="is">
<value>name of playlist</value>
</rule>
</node>
