2016-11-29, 23:00
2016-11-30, 10:57
Saying 'most' doesn't really help but I tested the latest on Windows and there's no difference for me.
2016-11-30, 12:53
I may shuld have been more clear on this, its about the autofilled list id="5". (which was used here.)
Kodi Jarvis:
(Screen: )
Kodi Krypton (latest nightly)
(Screen: )
i didnt change something in the List which shows the Picture Infos.
The Krypton Installation is "portable" beside Jarvis if this helps.
Regards.
EDIT:
List ID is id="5" (same as in Jarvis)
Kodi Jarvis:
(Screen: )
(Screen: )
Regards.
EDIT:
2016-11-30, 20:13
i did now a fresh and clean install off a nightly (14.11.) in a new Directory, starting from zero (0) ! To de shure not something from a older installation could cause this issues.
But - still the same!
2016-12-01, 06:51
All of the fields are populating on my machine...using the Windows nightly from 11-29.
2016-12-01, 11:05
Can you provide a sample image for testing purposes as mine are the same in nightly/stable?
2016-12-01, 17:35
(2016-12-01, 11:05)Hitcher Wrote: [ -> ]Can you provide a sample image for testing purposes as mine are the same in nightly/stable?
Yes, shure, i uploded the pict shown in the screenshots above on imgur
Link
i tested with several images, also some from my Smartphone, its the same with every Image/Photo tested, just the "Basic" tags show up, as shown in the screenshot.
Regards.
2016-12-01, 17:42
2016-12-01, 18:36
Strange,
what i did try now, is to store the Picture "local" on the same "Machine" (I usaly got them on my NAS). And if i do it that way the Infos show Up indeed.
I connect to my NAS via "SMB" have to do some research what happen if i copy a pictureFolder to an other PC and try it this way. Will Post again after the testing is done...
(the "funny" part is that if i use Jarvis on the same PC with the same source everyting is fine.. )
over "SMB"
local everything o.k.
over "SMB"
2016-12-01, 18:57
O.K. Looks like it could be a "SMB" problem/issue.
i did add a picture folder from an other PC in my network EDITvia SMB)/EDIT to test, and there are also just the "basic" Taginfos :confused: (both Windows "machines")
did also try to unplug and replug the LAN cable -> still the same.
