(2017-07-08, 15:59)Cosmicbase Wrote: [ -> ]With LE8 and Kodi 17 were no problems with mmal player.
That suggests that mmal will work as desired with one on the older builds from here (perhaps a couple of months back).
Narrowing down the first build with the problem would be useful to identifying the commit that caused the issue and hence finding a fix for it.
(2017-07-08, 16:12)popcornmix Wrote: [ -> ] (2017-07-08, 15:59)Cosmicbase Wrote: [ -> ]With LE8 and Kodi 17 were no problems with mmal player.
When I go back to LE8, does Amazon work then or not?
Greetings Cosmicbase
This is a debug-enabled #0708h build:
RPi2
It will create more detailed and useful crash logs for anyone experiencing crashes. Sorry about the odd build identifier but Kodi just merged a load of add-on changes and this was a debug-build I just happened to create prior to the latest merge.
(2017-07-08, 15:50)popcornmix Wrote: [ -> ]That looks the same as linkinsoldier's crash log, so I suspect it hasn't really gone with #0707, but it just a bit random.
Milhouse can you reproduce this crash? Can you confirm which build it started in?
(I'm away from home this weekend so my ability to debug/test is limited).
I've only seen it the once so far (first time for me in my #0708g test build but obviously it's there in at least #0706). I have tried to reproduce but so far failed - will try some more. If I can find a way to reliably reproduce then I'll identify the first build, but with a random failure that's much harder....
(2017-07-08, 16:22)Cosmicbase Wrote: [ -> ] (2017-07-08, 16:12)popcornmix Wrote: [ -> ] (2017-07-08, 15:59)Cosmicbase Wrote: [ -> ]With LE8 and Kodi 17 were no problems with mmal player.
No, there is no Amazon support in LE8 - it's currently only in these test builds.
However what popcornmix is asking is for you to go back methodically through the LE9 test builds in this thread until you identify when the playlist problem started - I normally start with a build from 6 months ago (eg #0101) and if that works, try #0201, if that works try #0301, if that is broken you know the problem is between #0201 and #0301 so now try #0215 and repeat the process until you identify the single build where the problem starts. It's possible the problem may have been introduced more than 6 months ago in which case go back further until you find a working build then work your way forwards. It's tedious, but usually very effective...
Once you've done that you can return to using the latest test build (with Amazon etc., but broken Youtube playlist). Popcornmix stands a much better chance of fixing the Youtube issue once he knows when it stopped working, then you can have both Amazon and Youtube playlists.
(2017-07-08, 15:38)J_E_F_F Wrote: [ -> ]I've been using these nightlies for a couple years now, and have installed them probably over 150 times. Is there a cleanup routine I should run/complete once a year or so to purge leftovers from old images
No not really. There's general Kodi maintenance that might be useful, such as purging your texture cache ("texturecache.py P") every once in a while, but there's not really anything specific to LibreELEC.
(2017-07-08, 15:38)J_E_F_F Wrote: [ -> ]or does installing a new nightly (via ssh) take care of everything?
ssh, Samba share, LE addon, Leopolds addon - the end result is always the same and should take care of everything.
(2017-07-08, 15:54)popcornmix Wrote: [ -> ] (2017-07-08, 10:49)linkinsoldier Wrote: [ -> ]2) When using Software Decode my Rpi gets pretty hot (getting heat warning icon) - I am using the official kodi case - am I the only one?
Software decode will inevitably get hotter than the more efficient hardware decode.
Is the video playback fine if you ignore the warning symbol?
If so, then "avoid_warnings=1" in config.txt will hide the warning.
No harm will occur - the throttling stops the temperature reaching undesirable levels.
If the throttling interferes with video playback then a themal solution is needed.
I use a FLIRC case which is *very* good and would solve the issue.
Removing the current case and aligning the pi pcb vertically may help with ventilation.
A stick on heat sink helps a little (but much less so than a case like the FLIRC).
Thanks for the feedback, I will keep testing and get back to you! What do you think about my idea with the aspect ratio?
About the case: I bought the official case from kodi (actually bought 4 of them for support [emoji6]) - isn't this the same case as the flirc case? I tried putting it on the left side which helps a little [emoji2]
Do you recommend do go to a more powerful system (e.g. Odroid-C2?) or is libreeelec RPi3 support better than for odroid? I originally bought the RPi3 for testing with the milhouse builds (love your work man!)
(2017-07-08, 17:46)linkinsoldier Wrote: [ -> ]is libreeelec RPi3 support better than for odroid? I originally bought the RPi3 for testing with the milhouse builds (love your work man!)
IMO rpi products have better (by order of magnitude) support than odroid
Hi!
I've problems with build #0707:
Visualization Spectrum: Not working
19:08:01.368 T:1942482960 ERROR: Add-on 'Spectrum' is using an incompatible API version for type 'Addon'. Kodi API min version = '1.0.10', add-on API version '1.0.9'
Netflix plugin: Not working (reboot kodi) but Amazon VOD plugin is working fine.
thanks...and thanks for all the hard work!
(2017-07-08, 18:20)asavah Wrote: [ -> ] (2017-07-08, 17:46)linkinsoldier Wrote: [ -> ]is libreeelec RPi3 support better than for odroid? I originally bought the RPi3 for testing with the milhouse builds (love your work man!)
Thanks! Maybe I have to wait for an rpi4 for full HD playback then [emoji6]
(2017-07-08, 19:25)linkinsoldier Wrote: [ -> ] (2017-07-08, 18:20)asavah Wrote: [ -> ] (2017-07-08, 17:46)linkinsoldier Wrote: [ -> ]is libreeelec RPi3 support better than for odroid? I originally bought the RPi3 for testing with the milhouse builds (love your work man!)
I am satisfied with the ODROID C2. You just have to find the right build.
Look at my signature for the example
(2017-07-08, 19:19)CygnusHyoga Wrote: [ -> ]Hi!
Many add-ons are broken right now.
You forgot to post your crashlog.
(2017-07-08, 17:46)linkinsoldier Wrote: [ -> ]About the case: I bought the official case from kodi (actually bought 4 of them for support [emoji6]) - isn't this the same case as the flirc case? I tried putting it on the left side which helps a little
Yes, kodi case is a rebranded flirc case and you should have no problems with temperature.
If you are having problems make sure the thermal pad is making good contact
(it should be touching both processor on Pi board and aluminium square that protrudes from top of case).
(2017-07-08, 19:47)Milhouse Wrote: [ -> ] (2017-07-08, 19:19)CygnusHyoga Wrote: [ -> ]Hi!
Music:
I disable Visualization Spectrum, and music is working again.
Netflix:
I disable Visualization Spectrum, change the settings in inputstream adaptive to:
Max. Resolution general decoder: Max
Max. Resolution secure decoder: Max
And netflix is working again
New LibreELEC.tv Leia build #0708:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.11.9 #1 Sat Jul 8 22:15:56 BST 2017 armv6l GNU/Linux
# vcgencmd version
Jul 3 2017 14:20:31
Copyright (c) 2012 Broadcom
version 4139c62f14cafdb7d918a3eaa0dbd68cf434e0d8 (tainted) (release)
# lsb_release
LibreELEC (Milhouse): devel-20170708221452-#0708-gb7dad37 [Build #0708]
# Kodi version
(18.0-ALPHA1 Git:734cda1). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (b7dad370,
changelog) and tip of
XBMC master (2f890498,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.11.y
- Includes latest bcm2835-driver master (446b2641, ahead +3)
- Includes latest kodi-platform master (36fb4937)
- Includes latest libcec master (3953f8dc, ahead +12)
- Includes latest libnfs master (df94ae93, ahead +56)
- Includes latest p8-platform master (2d90f986)
- Includes latest addons: inputstream.adaptive (db9b6a1a), inputstream.rtmp (6db3697a), peripheral.joystick (b4331919, +1), pvr.argustv (4e8c838b, +1), pvr.demo (f67dff13, +1), pvr.dvblink (640629ca, +1), pvr.dvbviewer (9faf2413, +1), pvr.filmon (1c9d2ebe, +1), pvr.hdhomerun (48868e44, +1), pvr.hts (1653a3a7, +5), pvr.iptvsimple (8ccf85cc, +1), pvr.mediaportal.tvserver (642f9af1, +1), pvr.mythtv (46748fcd, +3), pvr.nextpvr (03a3b714, +1), pvr.njoy (79e8e653, +1), pvr.octonet (020dd98e), pvr.pctv (00b76689, +2), pvr.stalker (9e28f125, +3), pvr.vbox (12d629c4, +1), pvr.vdr.vnsi (3473225b, +1), pvr.vuplus (55e4f5f9, +1), pvr.wmc (1d655540, +1)
- Include [env] compare: linux: update to linux-4.11.9
- Include [env] patch: inputstream.rtmp: disable outdated addons that no longer build
- Include [env] patch: tvheadend42: fixup ffmpeg patch
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:1469: samba: update to samba-4.6.4
- Include [env] PR:1726: [WIP] lirc: update to 0.10.0
- Include [env] PR:1746: linux config: allow to boot from SD Card reader
- Include [env] PR:1749: netbsd-curses: update to 4c156be
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:13: Added minimalistic support for PVR Addon API 5.3.0 (pvr.octonet)
- Include [pkg] PR:67: Revert "Revert "change smbd and nmbd location"" (service.libreelec.settings)
- Include [pkg] PR:352: Fix: set wrong variable (libcec)
- Include [pkg] PR:12110: smbclient: cleanup smbclient configuration
- Include [pkg] PR:12311: FIX: ensure real filename from videodb in playlists
Build Highlights:
- PVR Addon API changes for Leia
- New MusicDB schema v66 - better artist and album scraping during library update
- libnfs updates
Build Details:
- LibreELEC.tv:
- kodi: disable using debug fission (PR:1761, 1 commit, 1 file changed)
- alsa-lib: update patch (PR:1756, 1 commit, 1 file changed)
- busybox: use cttyhack (PR:1762, 1 commit, 2 files changed)
- XBMC:
- [PVR][addons] PVR Addon API changes for Leia (PR:12303, 6 commits, 29 files changed)
- Fix seeking with PTS values exceeding max int (PR:12442, 1 commit, 3 files changed)
- [Linux] Generic drm/kms implementation (PR:11955, 5 commits, 16 files changed)
- Better artist and album scraping during library update. (#12120) (07bc0d53)
- libnfs:
- TESTS: Add path adn valgrind tests for nfs_stat64() (422713e7)
- TESTS: Add path and valgrind leak tests for nfs_fstat64() (6144c017)
- Reformat libnfs.h (c9e546ba)
- Reformat socket.c (673860b1)
- Typos (27628975)
- TESTS Add tests for nfs_open() (4ed461ff)
- TETS: rename the tests (70197d5a)
- NFS4: Add support to nfs_mount() (56194dee)
- NFSv4: Add support for nfs_stat64() (2b764fa9)
- Make valgrind happy for libnfs_zdr_bytes (e27453b4)
- Increased resolution of PDU timeout from seconds to milliseconds (fb1efbe5)
- Bump the pdu timeout by 1000ms when we do not have clock_gettime() (fc677be6)
- Merge branch 'nfsv4' (4cb34e2c)
- WIN32: Update the project file with nfs_v4.c (and the renamed nfs_v3.c) (825d8c2a)
- Don't use random()/srandom() (546c9455)
- TESTS: Add tests for nfs_lstat64() (0d95058e)
- NFSv4: add support for nfs_lstat64() (5159b76e)
- Change the paths for the nfs includes from libnfs-private.h (5a6865c7)
- TESTS: Tweak timeout test settings (8df91763)
- Fix compiler warnings about cast from char* -> uint32_t* (dc9669ab)
- rpc->timeout does not need to be 64 bit (419e1969)
- pdu->timeout needs to be uint64_t (df94ae93)
- peripheral.joystick:
- force set of settings after AddonCreate (PR:118, 1 commit, 2 files changed)
- pvr.argustv:
- Added minimalistic support for PVR Addon API 5.3.0 (PR:71, 1 commit, 3 files changed)
- pvr.demo:
- Added minimalistic support for PVR Addon API 5.3.0 (PR:49, 1 commit, 2 files changed)
- pvr.dvblink:
- Added minimalistic support for PVR Addon API 5.3.0 (PR:91, 1 commit, 4 files changed)
- pvr.dvbviewer:
- Added minimalistic support for PVR Addon API 5.3.0 (PR:67, 1 commit, 3 files changed)
- pvr.filmon:
- Added minimalistic support for PVR Addon API 5.3.0 (PR:74, 1 commit, 3 files changed)
- pvr.hdhomerun:
- Added minimalistic support for PVR Addon API 5.3.0 (PR:49, 1 commit, 3 files changed)
- pvr.hts:
- Implement PVR Addon API changes for Leia (PR:315, 5 commits, 9 files changed)
- pvr.iptvsimple:
- Added minimalistic support for PVR Addon API 5.3.0 (PR:136, 1 commit, 3 files changed)
- pvr.mediaportal.tvserver:
- Added minimalistic support for PVR Addon API 5.3.0 (PR:72, 1 commit, 3 files changed)
- pvr.mythtv:
- Added minimalistic support for PVR Addon API 5.3.0 (PR:78, 1 commit, 3 files changed)
- Api 5.3.0 (PR:79, 2 commits, 2 files changed)
- pvr.nextpvr:
- Added minimalistic support for PVR Addon API 5.3.0 (PR:64, 1 commit, 3 files changed)
- pvr.njoy:
- Added minimalistic support for PVR Addon API 5.3.0 (PR:42, 1 commit, 3 files changed)
- pvr.pctv:
- Added minimalistic support for PVR Addon API 5.3.0 (PR:51, 1 commit, 3 files changed)
- Fix build (00b76689)
- pvr.stalker:
- Added minimalistic support for PVR Addon API 5.3.0 (PR:98, 1 commit, 3 files changed)
- src/CWatchdog.h: Fix gcc7 build (PR:92, 1 commit, 1 file changed)
- Fix build (bc3b7266)
- pvr.vbox:
- Added minimalistic support for PVR Addon API 5.3.0 (PR:197, 1 commit, 3 files changed)
- pvr.vuplus:
- Added minimalistic support for PVR Addon API 5.3.0 (PR:66, 1 commit, 3 files changed)
- pvr.wmc:
- Added minimalistic support for PVR Addon API 5.3.0 (PR:57, 1 commit, 3 files changed)
- Added: [pkg] PR:13: Added minimalistic support for PVR Addon API 5.3.0 (pvr.octonet)
