Hello everyone, at first, sorry for my bad english.
I have a Problem with my Netflix, its doesn´t work.
I have an RPi 3 with the newest Milhouse KODI
here are my Debug log.
http://sprunge.us/Sjcf
thx for helping
(2017-07-22, 13:46)Chrischan Wrote: [ -> ]Hello everyone, at first, sorry for my bad english.
thx for helping
Make sure OMX is disabled in Player settings - you only want to have MMAL enabled on RPi2/RPi3.
Milhouse
thanks it works,
Is there an way to let the OMX player enabled? Because i need The OMX Player for the Magine addon.
thx
(2017-07-22, 13:27)Malocher Wrote: [ -> ] (2017-07-21, 23:00)Milhouse Wrote: [ -> ]- Added: [pkg] PR:12518: Fix peripherals started before strings are loaded
Hmm, but in the CEC adapter is not yet a font to be seen - build #0721
Ich miss the fonts too. Can you fix it in the next build?
I've an issue with Netflix, crashing Kodi on specific TV show, only one at the moment as few I've tried played nicely.
The show is "The Last Kingdom".
I'm on latest build: LibreELEC (community): devel-20170720210344-#0720-g69a9671 (RPi2.arm)
asciidisco/plugin.video.netflix 0.11.16
Debug log:
http://sprunge.us/AXgh
Crash log:
http://sprunge.us/ihHW
When I go into system->input->peripherals no devices are shown so I cannot set cec settings. CEC works when I connect my raspberry pi to my tv. Have the settings been moved.
Regards Trevor
trevorjharris no they haven't been moved. What display are you connected to when the CEC peripheral isn't listed? Can you provide a debug log from when the device isn't listed. Note that CEC labels remain broken (not visible).
New LibreELEC.tv Leia build #0722:
RPi2
(Supercedes previous build)
# uname -a
Linux rpi22 4.12.3 #1 SMP Sat Jul 22 21:06:15 BST 2017 armv7l GNU/Linux
# vcgencmd version
Jul 22 2017 00:01:46
Copyright (c) 2012 Broadcom
version f52771674311a841405cea05e8738a526dd60ee1 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20170722210523-#0722-g555484a [Build #0722]
# Kodi version
(18.0-ALPHA1 Git:734cda1). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (555484a1,
changelog) and tip of
XBMC master (5749a3c2,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.12.y
- Includes latest bcm2835-driver master (dc9bc483, ahead +8)
- Includes latest kodi-platform master (36fb4937)
- Includes latest libcec master (8adc786b, ahead +26)
- Includes latest libnfs master (df94ae93, ahead +56)
- Includes latest p8-platform master (a822e196)
- Includes latest addons: inputstream.adaptive (0a32275a, +4), inputstream.rtmp (39d7979a), peripheral.joystick (6e18bc74), pvr.argustv (4e8c838b), pvr.demo (f67dff13), pvr.dvblink (640629ca), pvr.dvbviewer (9faf2413), pvr.filmon (1c9d2ebe), pvr.hdhomerun (48868e44), pvr.hts (1653a3a7), pvr.iptvsimple (8ccf85cc), pvr.mediaportal.tvserver (642f9af1), pvr.mythtv (13a240d3, +2), pvr.nextpvr (03a3b714), pvr.njoy (79e8e653), pvr.octonet (a77cf111), pvr.pctv (00b76689), pvr.stalker (9e28f125), pvr.vbox (12d629c4), pvr.vdr.vnsi (3473225b), pvr.vuplus (55e4f5f9), pvr.wmc (1d655540)
- Include [env] compare: kodi updates
- Include [env] compare: samba: make SMB3_11 the default protocol, don't force in kodi
- Include [env] compare: linux: update to linux-4.12.2
- Include [env] patch: inputstream.rtmp: disable outdated addons that no longer build
- Include [env] patch: scripts/image: hack to resolve nvidia.ko symbols
- Include [env] patch: tvheadend42: fixup ffmpeg patch
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:1726: [WIP] lirc: update to 0.10.0
- Include [env] PR:1773: init: make break after behaviour really break after
- Include [env] PR:1776: Don't cause system to hang on halt/reboot when net-booting
- Include [env] PR:1791: nss/nspr: include in main image [rfc]
- Include [env] PR:1816: RTL8812AU: update to RTL8812AU-887f8cc
- Include [pkg] patch: ffmpeg: hi10 build fix (ffmpeg)
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:12110: smbclient: cleanup smbclient configuration
- Include [pkg] PR:12311: FIX: ensure real filename from videodb in playlists
- Include [pkg] PR:12518: Fix peripherals started before strings are loaded
- Include [pkg] PR:12546: RetroPlayer: Fix black screen on playback
Build Highlights:
- Only RPi2 build today due to ffmpeg-related build issues with RPi (will be resolved early next week)
- New firmware (MMAL and ISP fixes)
- Backport "max protocol=SMB3_11" support from Samba 4.7-rc2
Quote:This makes the "client max protocol" setting redundant in LibreELEC LE9 builds, so this setting now defaults to "None" although you can still set SMB1/SMB2/SMB3 if required.
- ffmpeg: hevc: Initial 10-bit support
popcornmix Wrote:I've pushed out support for 10-bit hevc (and h.264) to newclock5. Very early days but I'm having success with 720p content.
Build Details:
- Firmware (Jul 22):
- firmware: MMAL: Avoid lockup with opaque stripes into opaque frame callback See: link
- firmware: RIL null_sink: Support MMAL opaque input. See: link
- firmware: arm_display: Avoid hang when display_rotate is used with vc4-kms-v3d driver. See: link
- firmware: 2ndstage: Fix printing of zero as a decimal in uart_printf
- firmware: cdi_camera: Allow GPIO control on FS and FE events
- firmware: IL ISP: Add option to alter the shift in the output stage
- firmware: IL ISP: Add option for adjusting the input CCM
- firmware: vc_image: fix size calcs for YUV_UV_16
- firmware: vc_image_helper: Add YUV 16 bit formats to second header
- firmware: isp: Avoid setting vpitch in YUVUV16 cases
- firmware: isp: Handle 16 bit yuv in ip_is_supported_format
- firmware: hello_fft: Fixup offset calculation when mapping/unmapping buffers. See: link
- LibreELEC.tv:
- intel-ucode: update to intel-ucode-20170707 (PR:1813, 2 commits, 2 files changed)
- udev: cleanup (PR:1800, 4 commits, 4 files changed)
- README.md: specifiy that patches retain upstream license, unless stat (PR:1819, 1 commit, 1 file changed)
- v4l-utils: fix racy udev rule (PR:1802, 2 commits, 3 files changed)
- XBMC:
- [pvr] drop channel guide button from info dialog + add channel guide to context menu (PR:12526, 3 commits, 4 files changed)
- Controllers: Code cleanup (PR:12527, 5 commits, 10 files changed)
- [bluray][simple menu] Search for a user provided list of playlists. (PR:12537, 1 commit, 2 files changed)
- [PlayListM3u] Get Mime-Type from #KODIPROP to avoid mime type checking (PR:12545, 1 commit, 1 file changed)
- MMALCodec: Add an extra buffer to picture pool (PR:12523, 1 commit, 1 file changed)
- CPeripheralCecAdapter: Execute application operations from application thread (PR:12524, 1 commit, 1 file changed)
- Texture: Fix constness of pixels (PR:12521, 1 commit, 2 files changed)
- fix build without bluray (PR:12540, 1 commit, 1 file changed)
- VideoPlayer: drop pvr SwitchChannel (PR:12510, 8 commits, 25 files changed)
- pvr.mythtv:
- newclock5:
- New commits in this build:
- MMAL: Initial support for more than 8bpp (67c94c65)
- RBP: Hide data in geometry class (ec468d88)
- MMAL: Support using the isp component for conversion of more than 8bpp (e2b30867)
- ffmpeg: hevc: Initial 10-bit support (8962e8b6)
- MMALFFmpeg: Tidy GetPlanes (40a9df1a)
- MMAL: Support MMAL_ENCODING_YUVUV64_16 (f124b721)
- fixup! RBP: Hide data in geometry class (44ab6cd8)
- MMAL: fixup alignment with sand formats (876ef7ca)
- MMAL: Improve error handling when allocations fail (359e0310)
- Commits no longer in build:
- Texture: Fix constness of pixels (d4fd3540)
- MMALCodec: Add an extra buffer to picture pool (9f46391a)
- Fix broken peripheral settings (af57111e)
- Fix "enable mouse" setting (4f5eed2c)
- Fix broken add-ons autoupdate setting (8386d0fd)
- CEC: Execute application operations from application thread (41db215f)
- Added: [env] compare: samba: make SMB3_11 the default protocol, don't force in kodi
- Added: [pkg] patch: ffmpeg: hi10 build fix (ffmpeg)
- Added: [pkg] PR:12546: RetroPlayer: Fix black screen on playback
garbear no luck with PR:12546 fix... Still experiencing black screen during playback on RPi3
Sent from my iPhone
My 10-bit HEVC samples work great, including a 1080p/24 sample. However, sometimes Kodi crashes when I try to FF/REW.
(2017-07-23, 01:22)smp1 Wrote: [ -> ]popcornmix Wrote:I've pushed out support for 10-bit hevc (and h.264) to newclock5. Very early days but I'm having success with 720p content.
Can you try this debug-enabled build #0722z:
RPi2
Reproduce the problem with FF/REW and then post a link to your crashlog.
A sample file that can be used to reproduce the issue would also be useful.
(2017-07-23, 01:00)weppa Wrote: [ -> ]@garbear no luck with PR:12546 fix... Still experiencing black screen during playback on RPi3
Sent from my iPhone (typie typie)
I've the same problem, still black screen in RPi3 in Retroplayer. Game load OK, i can heard the game music.
09:19:22.097 T:1942437904 ERROR: AddOnLog: NES / Famicom (Nestopia UE): Kodi setting setting unknown to libretro!
09:19:23.367 T:1942437904 ERROR: AddOnLog: NES / Famicom (Nestopia UE): custom.pal not found in system directory.
09:19:23.368 T:1942437904 ERROR: AddOnLog: NES / Famicom (Nestopia UE): NstDatabase.xml required to detect region and some mappers.
09:19:23.749 T:1942437904 ERROR: Failed to open zip://smb%3a%2f%2f192.168.66.5%3a445%2femu%2fNes%2fRoms%2fD%2fdarkman%20u.zip/darkman u.xml: Failed to open file
09:19:23.749 T:1942437904 ERROR: Previous line repeats 1 times.
09:19:23.749 T:1942437904 ERROR: Failed to query savestate zip://smb%3a%2f%2f192.168.66.5%3a445%2femu%2fNes%2fRoms%2fD%2fdarkman%20u.zip/darkman u.xml
09:19:23.749 T:1942437904 ERROR: RetroPlayer: Failed to load savestate
09:19:23.813 T:1942437904 WARNING: CRenderManager::Configure - queue size too small (2, 6, 1)
I get the errot message that openweathermap could not start or will not work everytime when I start my raspberry. I checked the addon dependencies and could see that the script.module.pil is not available. Is this module not integrated? Or do I have to install it from another source? And if yes, where do I find this module?
Anybody also having this issue?
