(2017-07-24, 12:56)popcornmix Wrote: [ -> ] (2017-07-24, 10:46)Malocher Wrote: [ -> ]build #0723
The TV streams are no longer open
I suspect this is deliberate, PR12550 removes a deprectated API. See:
https://forum.kodi.tv/showthread.php?tid=259830
I'm not sure what the solution is for this - I suspect iptv simple add-on needs fixing
Oh then I'll work with build #0722
(2017-07-24, 13:16)Malocher Wrote: [ -> ]Oh then I'll work with build #0722
It may be best to create an issue
here.
It looks like the iptv client is broken as it hasn't updated from using an API that was
deprecated 18 months ago.
(2017-07-24, 06:41)linkinsoldier Wrote: [ -> ]Tried 723 and unfortunately the controller mapping Bug is still present. I tried a few things today and found, that it shows the motion controllers in peripherals - didn't do that before as far as I remember!
Also it now shows the same controller twice in libreeelec settings -> Bluetooth!
When I try to delete one kodi reboots (will post crash log tonight).
Also: same problem occurs when controller is connected via USB! Kodi for some reason is assigning the controller twice!
I continued my previous test (
https://forum.kodi.tv/showthread.php?tid...pid2620286) borrowing an generic USB SNES clone pad and it works as expected:
https://pastebin.com/yUmKwEmv
15:12:47.578 T:1779332000 NOTICE: Register - new joystick device registered on addon->peripheral.joystick/0: USB Gamepad
So it is an issue just for gamepads with motion sensors, starting in 0714 build...
any help or clue?
(2017-07-24, 15:09)popcornmix Wrote: [ -> ] (2017-07-24, 13:16)Malocher Wrote: [ -> ]Oh then I'll work with build #0722
It may be best to create an issue here.
It looks like the iptv client is broken as it hasn't updated from using an API that was deprecated 18 months ago.
The installed version is 3.0.2.1 ..If I want to update comes an error.
Here is a version v3.1.0 -> - Updated to PVR addon API v5.3.0
https://github.com/kodi-pvr/pvr.iptvsimple
I will try to update via ZIP file
(2017-07-21, 18:05)bill_orange Wrote: [ -> ] (2017-07-20, 17:57)bill_orange Wrote: [ -> ] (2017-07-19, 19:07)bill_orange Wrote: [ -> ]I discovered a problem with remote access when testing the wireless network driver.
On builds (at least) #0717 and #0718 I can no longer SSH in when KODI is not selected (ie. The TV and stereo connected by CEC are OFF and KODI ON).
I will do further testing to find out the build when this worked. It could be something in CEC settings changed but I still can not see the left side of the CEC setup screen.
*Edit*
Yes, build #0716 does not have the problem.
Build #0719 appears to have corrected this problem.
Well, I thought this problem was behind me, but my test procedure may have been in error. I found on build #0720 that I can not connect with SSH or WinSCP after a while. A while might be around eight hours. If I don't touch anything but turn WiFi OFF and then ON again all is well. WiFi was not dead in that Weather was updating. Weird.
So maybe this is a WiFi driver issues. This is all using an RP3 with the built in Broadcom WiFi chip.
Can anyone reproduce this? Would any of my logs show anything helpful? If so, let me know and I will post.
Here's a log file. At the start I can not control Kodi remotely. I turn Remote Control and Wireless on and off. Remote control returns.
17:41:10.259 T:1942629696 NOTICE: special://profile/ is mapped to: special://masterprofile/
17:41:10.259 T:1942629696 NOTICE: -----------------------------------------------------------------------
17:41:10.259 T:1942629696 NOTICE: Starting Kodi (18.0-ALPHA1 Git:734cda1). Platform: Linux ARM 32-bit
17:41:10.259 T:1942629696 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
17:41:10.259 T:1942629696 NOTICE: Kodi compiled Jul 23 2017 by GCC 6.2.0 for Linux ARM 32-bit version 4.12.3 (265219)
17:41:10.259 T:1942629696 NOTICE: Running on LibreELEC (Milhouse): devel-20170723210302-#0723-g65e3131 [Build #0723] 9.0, kernel: Linux ARM 32-bit version 4.12.3
17:41:10.259 T:1942629696 NOTICE: FFmpeg version/source: ffmpeg-3.3-kodi
17:41:10.259 T:1942629696 NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
17:41:10.259 T:1942629696 NOTICE: ARM Features: Neon disabled
17:41:10.259 T:1942629696 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi/
17:41:10.260 T:1942629696 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
17:41:10.260 T:1942629696 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
17:41:10.260 T:1942629696 NOTICE: special://masterprofile/ is mapped to: /storage/.kodi/userdata
17:41:10.260 T:1942629696 NOTICE: special://envhome/ is mapped to: /storage
17:41:10.260 T:1942629696 NOTICE: special://home/ is mapped to: /storage/.kodi
17:41:10.260 T:1942629696 NOTICE: special://temp/ is mapped to: /storage/.kodi/temp
17:41:10.260 T:1942629696 NOTICE: special://logpath/ is mapped to: /storage/.kodi/temp
17:41:10.260 T:1942629696 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
17:41:10.260 T:1942629696 NOTICE: Local hostname: LibreELEC
17:41:10.260 T:1942629696 NOTICE: Log File is located: /storage/.kodi/temp//kodi.log
17:41:10.260 T:1942629696 NOTICE: -----------------------------------------------------------------------
17:41:10.445 T:1942629696 NOTICE: load settings...
17:41:10.490 T:1942629696 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
17:41:10.525 T:1942629696 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/rbp.xml
17:41:10.528 T:1942629696 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/rbp2.xml
17:41:10.532 T:1932522400 DEBUG: Thread FDEventMonitor start, auto delete: false
17:41:10.548 T:1942629696 INFO: CAESinkALSA - Unable to open device "default" for playback
17:41:10.577 T:1942629696 DEBUG: PulseAudio: Context authorizing
17:41:10.579 T:1942629696 DEBUG: PulseAudio: Context setting name
17:41:10.579 T:1942629696 DEBUG: PulseAudio: Context ready
17:41:10.581 T:1942629696 NOTICE: Found 2 Lists of Devices
17:41:10.581 T:1942629696 NOTICE: Enumerated PI devices:
17:41:10.581 T:1942629696 NOTICE: Device 1
17:41:10.582 T:1942629696 NOTICE: m_deviceName : HDMI
17:41:10.582 T:1942629696 NOTICE: m_displayName : HDMI
17:41:10.582 T:1942629696 NOTICE: m_displayNameExtra:
17:41:10.582 T:1942629696 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
17:41:10.582 T:1942629696 NOTICE: m_channels : FL, FR
17:41:10.582 T:1942629696 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
17:41:10.582 T:1942629696 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
17:41:10.582 T:1942629696 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
17:41:10.582 T:1942629696 NOTICE: Device 2
17:41:10.582 T:1942629696 NOTICE: m_deviceName : Analogue
17:41:10.582 T:1942629696 NOTICE: m_displayName : Analogue
17:41:10.582 T:1942629696 NOTICE: m_deviceType : AE_DEVTYPE_PCM
17:41:10.582 T:1942629696 NOTICE: m_sampleRates : 48000
17:41:10.582 T:1942629696 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
17:41:10.582 T:1942629696 NOTICE: m_streamTypes : No passthrough capabilities
17:41:10.582 T:1942629696 NOTICE: Device 3
17:41:10.583 T:1942629696 NOTICE: m_deviceName : Both
17:41:10.583 T:1942629696 NOTICE: m_displayName : HDMI and Analogue
17:41:10.583 T:1942629696 NOTICE: m_displayNameExtra:
17:41:10.583 T:1942629696 NOTICE: m_deviceType : AE_DEVTYPE_PCM
17:41:10.583 T:1942629696 NOTICE: m_channels : FL, FR
17:41:10.583 T:1942629696 NOTICE: m_sampleRates : 48000
17:41:10.583 T:1942629696 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
17:41:10.583 T:1942629696 NOTICE: m_streamTypes : No passthrough capabilities
17:41:10.583 T:1942629696 NOTICE: Enumerated PULSE devices:
17:41:10.583 T:1942629696 NOTICE: Device 1
17:41:10.583 T:1942629696 NOTICE: m_deviceName : Default
17:41:10.583 T:1942629696 NOTICE: m_displayName : Default
17:41:10.583 T:1942629696 NOTICE: m_displayNameExtra: Bluetooth Audio (PULSEAUDIO)
17:41:10.583 T:1942629696 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
17:41:10.583 T:1942629696 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
17:41:10.585 T:1942629696 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/appliance.xml
17:41:10.588 T:1942629696 DEBUG: SECTION:LoadDLL(libbluray.so.2)
17:41:10.590 T:1942629696 DEBUG: Loading: libbluray.so.2
17:41:10.647 T:1942629696 DEBUG: CSkinSettings: no <skinsettings> tag found
17:41:10.649 T:1942629696 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
17:41:10.649 T:1942629696 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="utf-8" ?>
<advancedsettings>
<showexitbutton>false</showexitbutton>
<remotedelay>1</remotedelay>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<fanartres>720</fanartres>
<imageres>540</imageres>
</advancedsettings>
17:41:10.649 T:1942629696 WARNING: CSettingsManager: missing version attribute
17:41:10.651 T:1942629696 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
17:41:10.651 T:1942629696 NOTICE: Default Video Player: VideoPlayer
17:41:10.651 T:1942629696 NOTICE: Default Audio Player: paplayer
17:41:10.652 T:1942629696 NOTICE: Disabled debug logging due to GUI setting. Level 0.
17:41:10.652 T:1942629696 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
17:41:10.652 T:1942629696 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
17:41:10.653 T:1942629696 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
17:41:10.654 T:1942629696 NOTICE: Loaded playercorefactory configuration
17:41:10.655 T:1942629696 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
17:41:10.655 T:1942629696 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
17:41:10.775 T:1942629696 NOTICE: Running database version Addons27
17:41:11.122 T:1942629696 NOTICE: ADDONS: Using repository repository.xbmc.org
17:41:11.122 T:1942629696 NOTICE: ADDONS: Using repository repository.kodi.game
17:41:11.123 T:1942629696 NOTICE: ADDONS: Using repository repository.libreelec.tv
17:41:11.123 T:1942629696 NOTICE: ADDONS: Using repository repository.retroplayer.libreelec.tv
17:41:11.334 T:1942629696 NOTICE: Raspberry PI firmware version: Jul 22 2017 00:01:46
Copyright (c) 2012 Broadcom
version f52771674311a841405cea05e8738a526dd60ee1 (clean) (release)
17:41:11.334 T:1942629696 NOTICE: ARM mem: 752MB GPU mem: 256MB MPG2:0 WVC1:0
17:41:11.334 T:1942629696 NOTICE: cache.memorysize: 20MB libass.cache: 21MB
17:41:11.335 T:1942629696 NOTICE: Config:
arm_freq=1200
audio_pwm_mode=1
config_hdmi_boost=5
core_freq=400
desired_osc_freq=0x36ee80
disable_commandline_tags=2
disable_l2cache=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=300
hdmi_channel_map=0x13b3e4c8
hdmi_force_cec_address=65535
hdmi_ignore_cec_init=1
init_uart_clock=0x2dc6c00
lcd_framerate=60
over_voltage_avs=0x1e848
over_voltage_avs_boost=0x1e848
overscan_bottom=48
overscan_left=48
overscan_right=48
overscan_top=48
pause_burst_frames=1
program_serial_random=1
sdram_freq=450
temp_limit=85
device_tree=-
17:41:11.336 T:1942629696 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
17:41:11.336 T:1942629696 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz
17:41:11.336 T:1942629696 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 72.000000 Hz
17:41:11.336 T:1942629696 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 71.928070 Hz
17:41:11.336 T:1942629696 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 75.000000 Hz
17:41:11.336 T:1942629696 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 60.000000 Hz
17:41:11.336 T:1942629696 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 59.940063 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 72.000000 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 71.928070 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 75.000000 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 60.000000 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 59.940063 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 70.000000 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 75.000000 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 1152 x 864 for display 0 with 1152 x 864 @ 75.000000 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 1280 x 800 for display 0 with 1280 x 800 @ 60.000000 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 1280 x 800 for display 0 with 1280 x 800 @ 59.940063 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 60.000000 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 59.940063 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 75.000000 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 1440 x 900 for display 0 with 1440 x 900 @ 60.000000 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 1440 x 900 for display 0 with 1440 x 900 @ 59.940063 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 1680 x 1050 for display 0 with 1680 x 1050 @ 60.000000 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 1680 x 1050 for display 0 with 1680 x 1050 @ 59.940063 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 1366 x 768 for display 0 with 1366 x 768 @ 60.000000 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 1366 x 768 for display 0 with 1366 x 768 @ 59.940063 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 1600 x 900 for display 0 with 1600 x 900 @ 60.000000 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 1600 x 900 for display 0 with 1600 x 900 @ 59.940063 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 59.940063 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
17:41:11.337 T:1942629696 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940063 Hz
17:41:11.338 T:1942629696 NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
17:41:11.338 T:1942629696 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
17:41:11.338 T:1942629696 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
17:41:11.338 T:1942629696 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
17:41:11.338 T:1942629696 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 23.976025 Hz
17:41:11.338 T:1942629696 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 25.000000 Hz
17:41:11.338 T:1942629696 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 30.000000 Hz
17:41:11.338 T:1942629696 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 29.970032 Hz
17:41:11.338 T:1942629696 NOTICE: Found ([email protected]) at 48, setting to RES_DESKTOP at 16
17:41:11.339 T:1942629696 NOTICE: Checking resolution 16
17:41:13.719 T:1942629696 NOTICE: GL_VENDOR = Broadcom
17:41:13.719 T:1942629696 NOTICE: GL_RENDERER = VideoCore IV HW
17:41:13.720 T:1942629696 NOTICE: GL_VERSION = OpenGL ES 2.0
17:41:13.720 T:1942629696 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
17:41:13.720 T:1942629696 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
17:41:14.539 T:1942629696 ERROR: Keymapping error: no such action 'save' defined
17:41:14.539 T:1942629696 ERROR: Keymapping error: no such action 'load' defined
17:41:14.539 T:1942629696 ERROR: Keymapping error: no such action 'saveslotincrease' defined
17:41:14.539 T:1942629696 ERROR: Keymapping error: no such action 'saveslotdecrease' defined
17:41:14.539 T:1942629696 ERROR: Previous line repeats 1 times.
17:41:14.875 T:1854927776 NOTICE: Running database version Addons27
17:41:14.878 T:1854927776 NOTICE: Running database version ViewModes6
17:41:14.964 T:1854927776 NOTICE: Running database version Textures13
17:41:15.589 T:1854927776 NOTICE: Running database version MyMusic66
17:41:15.634 T:1854927776 NOTICE: Running database version MyVideos108
17:41:15.640 T:1854927776 NOTICE: Running database version TV30
17:41:15.643 T:1854927776 NOTICE: Running database version Epg11
17:41:15.647 T:1942629696 NOTICE: start dvd mediatype detection
17:41:15.712 T:1942629696 NOTICE: load skin from: /usr/share/kodi/addons/skin.estuary (version: 2.0.2)
17:41:16.326 T:1942629696 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
17:41:16.991 T:1942629696 NOTICE: Register - new joystickemulation device registered on application->1: Keyboard player (0000:0000)
17:41:17.068 T:1942629696 NOTICE: initialize done
17:41:17.068 T:1942629696 NOTICE: Running the application...
17:41:17.102 T:1942629696 NOTICE: starting zeroconf publishing
17:41:17.104 T:1942629696 NOTICE: CWebServer[8080]: Started
17:41:17.104 T:1942629696 NOTICE: starting upnp client
17:41:17.138 T:1942629696 NOTICE: starting upnp server
17:41:17.147 T:1942629696 NOTICE: starting upnp controller
17:41:17.147 T:1942629696 NOTICE: starting upnp renderer
17:41:17.183 T:1529840544 NOTICE: ES: Starting UDP Event server on port 9777
17:41:17.183 T:1529840544 NOTICE: UDP: Listening on port 9777 (ipv6 : true)
17:41:17.288 T:1942629696 NOTICE: Logitech K400: keys:35 ext:64 but:16 rel:5 abs:0 m_deviceType:d bits:111000
17:41:17.360 T:1756566432 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
17:41:17.385 T:1942629696 NOTICE: VNCServer SimKey: keys:35 ext:415 but:16 rel:0 abs:2 m_deviceType:d bits:101110
17:41:17.645 T:1756566432 NOTICE: Logitech K400: keys:35 ext:64 but:16 rel:5 abs:0 m_deviceType:d bits:111000
17:41:17.725 T:1756566432 NOTICE: VNCServer SimKey: keys:35 ext:415 but:16 rel:0 abs:2 m_deviceType:d bits:101110
17:41:18.569 T:1819276192 NOTICE: [plugin.video.youtube] Startup: detected Krypton (Kodi-18.0), setting DASH_SUPPORT_BUILTIN = False, DASH_SUPPORT_ADDON = True
17:41:18.949 T:1786135456 NOTICE: AddOnLog: PVR IPTV Simple Client: Loaded 245 channels.
17:41:19.059 T:1854927776 NOTICE: Start - EPG thread started
17:41:19.195 T:1679180704 NOTICE: Skin Helper Widgets --> Backgroundservice started
17:41:20.095 T:1667883936 NOTICE: AddOnLog: PVR IPTV Simple Client: EPG file path is not configured. EPG not loaded.
17:41:22.815 T:1552495520 WARNING: CPlayerCoreFactory::GetPlayer(TX-NR626): no such player: TX-NR626
17:45:50.604 T:1798988704 WARNING: CPlayerCoreFactory::GetPlayer([TV]Samsung LED50): no such player: [TV]Samsung LED50
17:46:20.173 T:1667883936 NOTICE: AddOnLog: PVR IPTV Simple Client: EPG file path is not configured. EPG not loaded.
06:28:30.761 T:1942629696 NOTICE: Previous line repeats 152 times.
06:28:30.761 T:1942629696 ERROR: CBinaryAddonManager::GetInstalledAddonInfo: Requested addon 'visualization.spectrum' unknown as binary
06:29:23.074 T:1552495520 ERROR: GetDirectory - Error getting
06:29:23.166 T:1942629696 ERROR: Previous line repeats 3 times.
06:29:23.166 T:1942629696 ERROR: CBinaryAddonManager::GetInstalledAddonInfo: Requested addon 'visualization.spectrum' unknown as binary
06:32:39.841 T:1942629696 ERROR: Previous line repeats 2 times.
06:32:39.841 T:1942629696 ERROR: Window Translator: Can't find window videolibrary
06:32:39.841 T:1942629696 WARNING: Label Formating: $VAR[GlobalFanartVar] is not defined
06:32:39.950 T:1942629696 ERROR: Control 1000 in window 13001 has been asked to focus, but it can't
06:32:40.128 T:1942629696 ERROR: CBinaryAddonManager::GetInstalledAddonInfo: Requested addon 'visualization.spectrum' unknown as binary
06:32:46.406 T:1414910880 ERROR: ## LibreELEC Addon ## oeWindows.mainWindow::onFocus(1100) ## ERROR: (AttributeError("'NoneType' object has no attribute 'getProperty'",))
06:32:46.407 T:1414910880 ERROR: Traceback (most recent call last):
File "/home/neil/projects/LibreELEC.tv/build.LibreELEC-RPi2.arm-9.0-devel/LibreELEC-settings-a40fb4f/.install_pkg/usr/share/kodi/addons/service.libreelec.settings/resources/lib/oeWindows.py", line 365, in onFocus
AttributeError: 'NoneType' object has no attribute 'getProperty'
06:32:46.455 T:1942629696 ERROR: Control 1200 in window 13001 has been asked to focus, but it can't
06:33:37.258 T:1942629696 ERROR: Previous line repeats 6 times.
06:33:37.259 T:1942629696 ERROR: CBinaryAddonManager::GetInstalledAddonInfo: Requested addon 'visualization.spectrum' unknown as binary
06:34:22.158 T:1942629696 ERROR: Previous line repeats 4 times.
06:34:22.158 T:1942629696 NOTICE: CWebServer[8080]: Stopped
06:34:24.174 T:1942629696 NOTICE: CWebServer[8080]: Started
06:34:42.994 T:1942629696 ERROR: CBinaryAddonManager::GetInstalledAddonInfo: Requested addon 'visualization.spectrum' unknown as binary
06:38:11.911 T:1942629696 ERROR: Previous line repeats 4 times.
06:38:11.914 T:1942629696 ERROR: Window Translator: Can't find window videolibrary
06:38:11.914 T:1942629696 WARNING: Label Formating: $VAR[GlobalFanartVar] is not defined
06:38:12.021 T:1942629696 ERROR: Control 1000 in window 13000 has been asked to focus, but it can't
06:38:12.198 T:1942629696 ERROR: CBinaryAddonManager::GetInstalledAddonInfo: Requested addon 'visualization.spectrum' unknown as binary
(2017-07-24, 04:24)3DBuff Wrote: [ -> ]3D ISO file playback is broken from #0708.
#0707 is the last working version, tested on 2 separate systems.
#0708 does not play at all. Later versions try to make SBS from frame packing.
Are you sure about the build number? #0707 would be more likely to be the breaking build as it has bluray related changes in.
#0708 doesn't have any changes that look relevant.
(2017-07-24, 15:32)bite_your_idols Wrote: [ -> ] (2017-07-24, 06:41)linkinsoldier Wrote: [ -> ]Tried 723 and unfortunately the controller mapping Bug is still present. I tried a few things today and found, that it shows the motion controllers in peripherals - didn't do that before as far as I remember!
I continued my previous test (https://forum.kodi.tv/showthread.php?tid...pid2620286) borrowing an generic USB SNES clone pad and it works as expected:
any help or clue?
That would come in line with my guess that "motion sensors" and "rest of the ps3 controller" are handled as 2 separate controller starting with #714.
@milhouse/@garbear: what do you think of our theories?
(2017-07-24, 15:44)Malocher Wrote: [ -> ]The installed version is 3.0.2.1 ..If I want to update comes an error.
The installed version is 3.1.0. Actually, it's 999.3.1.0 and you won't be able to install any other version.
Definitely sounds like a bluetooth driver, but there's no reason we can't fix this in Kodi. Kodi should ignore the controller unless you've mapped it in the controller window. Is this the case?
(2017-07-24, 18:36)Milhouse Wrote: [ -> ] (2017-07-24, 15:44)Malocher Wrote: [ -> ]The installed version is 3.0.2.1 ..If I want to update comes an error.
Yes, I already noticed
When I try to update comes the error :
"The dependency on xbmc.pvr in version 5.2.1. Could not be resolved "
(2017-07-24, 18:36)garbear Wrote: [ -> ]Definitely sounds like a bluetooth driver, but there's no reason we can't fix this in Kodi. Kodi should ignore the controller unless you've mapped it in the controller window. Is this the case?
Nope, I actually select "no" when I was asked If I want to configure it (also deleted and tried yes but no change...). Side note: this message does only pop up with #714 or newer...
Any way we can assist more to find and fix this bug? Should we create a bug ticket (where?)?
(2017-07-24, 18:50)Malocher Wrote: [ -> ]Yes, I already noticed
Not surprising when you're attempting to "update" to an older 3.0.2.1 version designed for Kodi 17!
The version you have is the latest & greatest, if it doesn't work then you should contact the addon maintainer as explained earlier, via github.
as I
posted before it happens using bluettoh and also using USB connection both in DS3 and DS4 gamepads... I wonder what change in 0704 can produce this behaviour that assings joysticks twice...
Milhouse / @
garbear do you need any additional info, log, steps or escenario to find out what is wrong with kodi? Maybe it is happening also in Generic builds but I can not test it on that platform...
I got a hang when watching 1080i50 livetv. This is the only channel where I have hangs after some minutes.
ssh login is possible but only power cycle brings sytem back. (systemctl stop kodi doesn't work).
http://sprunge.us/RPWA
