Just to be sure: when I try to start from scratch, can I ssh and mv .kodi .kodibackup and reboot or do I have to start from a new SD card image?
Renaming .kodi to .kodibackup and rebooting should be sufficient in most cases.
New LibreELEC.tv Leia build #0728:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.12.3 #1 Fri Jul 28 22:06:42 BST 2017 armv6l GNU/Linux
# vcgencmd version
Jul 28 2017 20:20:00
Copyright (c) 2012 Broadcom
version 6716e816fd1614c326071d86188976b5fbf9c22b (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20170728220536-#0728-g7a98f8c [Build #0728]
# Kodi version
(18.0-ALPHA1 Git:4c7c4f0). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (7a98f8c7,
changelog) and tip of
XBMC master (4c7c4f0e,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.12.y
- Includes latest bcm2835-driver master (23047785, ahead +10)
- Includes latest kodi-platform master (36fb4937)
- Includes latest libcec master (8adc786b, ahead +26)
- Includes latest libnfs master (df94ae93, ahead +56)
- Includes latest p8-platform master (a822e196)
- Includes latest addons: inputstream.adaptive (e298e958, +8), inputstream.rtmp (39d7979a), peripheral.joystick (1815c0fb, +1), pvr.argustv (4e8c838b), pvr.demo (f67dff13), pvr.dvblink (640629ca), pvr.dvbviewer (9faf2413), pvr.filmon (1c9d2ebe), pvr.hdhomerun (48868e44), pvr.hts (878757a9, +3), pvr.iptvsimple (8ccf85cc), pvr.mediaportal.tvserver (d7a9acdb, +1), pvr.mythtv (4704f721, +5), pvr.nextpvr (03a3b714), pvr.njoy (79e8e653), pvr.octonet (a77cf111), pvr.pctv (00b76689), pvr.stalker (9e28f125), pvr.vbox (12d629c4), pvr.vdr.vnsi (9268f008, +1), pvr.vuplus (55e4f5f9), pvr.wmc (1d655540)
- Include [env] compare: kodi updates
- Include [env] compare: linux: update to linux-4.12.3
- Include [env] patch: pvr addons: disable broken addons
- Include [env] patch: inputstream.rtmp: disable outdated addons that no longer build
- Include [env] patch: rev hack for kodi
- Include [env] patch: tvheadend42: fixup ffmpeg patch
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:1726: [WIP] lirc: update to 0.10.0
- Include [env] PR:1773: init: make break after behaviour really break after
- Include [env] PR:1776: Don't cause system to hang on halt/reboot when net-booting
- Include [env] PR:1791: nss/nspr: include in main image [rfc]
- Include [env] PR:1824: samba: make SMB3_11 the default protocol, don't force in kodi
- Include [env] PR:1835: add support for optional kernel modules in image and from addons
- Include [env] PR:1844: avahi: cleanup
- Include [pkg] patch: #temp: newclock5 build fix
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:12110: smbclient: cleanup smbclient configuration
- Include [pkg] PR:12311: FIX: ensure real filename from videodb in playlists
Build Highlights:
- New firmware (default to total_mem=1024)
popcornmix Wrote:I finally reproduced the total_mem=1024 crash some users had reported. Turns out it occurs when GPU logging buffer wraps around. Presumable affected users has something generating logging messages (perhaps hdmi/CEC). I've now enabled total_mem=1024 as a default. Hopefully that is all good now.
- add support for optional kernel modules in image and from addons
Build Details:
- Firmware (Jul 28):
- bootcode: Default to using total_mem=1024
- firmware: logging: Avoid wraparound issue with total_mem=1024
- firmware: armstubs: Add wfe to ARMv7/ARMv8-32 stubs. See: link
- firmware: arm_loader: Use ethernet0 as fallback for placing DT MAC address. See: link
- firmware: dt-blob: Remove Zero W static I2C0 mapping on 28 & 29. See: link
- LibreELEC.tv:
- samba: fix tdb deadlock (PR:1836, 2 commits, 2 files changed)
- XBMC:
- Controller window: Support mapping relative pointers (PR:12556, 2 commits, 24 files changed)
- [depends] Fix depends dependencies (PR:12581, 4 commits, 1 file changed)
- [depends] bump freetype to 2.8 (PR:12584, 1 commit, 1 file changed)
- VideoPlayer: vdpau - flush ffmpeg on release and error (PR:12582, 1 commit, 2 files changed)
- [PVR] Some cleanup and optimization. (PR:12583, 1 commit, 3 files changed)
- add dynamic URLs to fileItems (PR:12585, 1 commit, 13 files changed)
- skin.estouchy 2.0.5 (PR:12558, 1 commit, 6 files changed)
- peripheral.joystick:
- [Peripheral API] Update to v1.3.4: relative pointer support (PR:120, 1 commit, 10 files changed)
- Added: [env] PR:1835: add support for optional kernel modules in image and from addons
- Added: [env] PR:1844: avahi: cleanup
- Added: [pkg] patch: #temp: newclock5 build fix
(2017-07-28, 23:34)Milhouse Wrote: [ -> ]Build Highlights:
So we can
remove total_mem=1024 from config.txt and still get the benefit?
Simple iptv client does not work anymore.
Is there an alternative to simple iptv client in which I can use m3u, epg-xml and chanel logos of local.
I would suggest you stick with a build from before all the PVR breakage, until the fixes are in (no ETA on that, btw).
I have a lot of SQL errors in the log ?
ERROR: SQL: [TV31.db] SQL error or missing database
Query: ALTER TABLE channels DROP bWasPlayingOnQuit
https://pastebin.com/q5dsvThV
Malocher yes, it's caused by PR12548 in #0724 using invalid SQL. The developer has been notified.
(2017-07-29, 10:27)Milhouse Wrote: [ -> ]@Malocher yes, it's caused by PR12548 in #0724 using invalid SQL. The developer has been notified.
I have the same problem (I delete the TVxx.db to fixit) and after this I've problems with the Tv next air script/plugin.
Log:
http://sprunge.us/aaYT
Is it possible tp play HEVC 1080p on a raspberry pi2 with this builds?
I overclocked my pi2 but it plays about couple of minutes and the my pi2 locked up.
(2017-07-29, 20:27)Pienoet Wrote: [ -> ]Is it possible tp play HEVC 1080p on a raspberry pi2 with this builds?
It might be overheating. If you could kindly provide a little more information on your overclock settings, what case or heat sink you are using and the bit rate of the HEVC film you were trying to watch. Then I am sure some of the more experienced members of this forum would be able to assist you.
(2017-07-27, 18:04)agb2 Wrote: [ -> ] (2017-07-25, 18:21)agb2 Wrote: [ -> ]Refresh button.
On #724 the Refresh button in the VideoInfo window no longer exists.
It isn't there at all on Estuary and is greyed out in Confluence and derivatives.
This wasn't mentioned in the 'Changes to the skinning engine for Kodi Leia' thread
https://forum.kodi.tv/showthread.php?tid=298565
Since I don't normally use Estuary, it may have gone missing ages ago.
I can't say for certain that #724 is the first build with this situation in Confluence, but I do use the button
quite a bit, so I would think I'd have noticed.
Any ideas?
No one else seeing this?
Should I post in some other forum? It does appear to be LE 18 related,
Hmm. As of #728, this problem has gone away!
I haven't tested on all intermediate builds, but definitely OK now.
