(2016-12-02, 04:19)Milhouse Wrote: [ -> ]How are you determining RAM usage, with bcmstat.sh or something else?
Ok, nevermind my previous post. I went back to older build, the RAM usage is pretty much the same after a fresh boot (I used "System Information" to check).
I'm having an issue with the recording of the HDTV channels. I'm recording to an SMB shared folder on a Windows 10 PC. The low bitrate SD channels are OK but HDTV stream always get corrupted after ~20 seconds. I use the latest VDR/VNSI. The issue is also present in older builds (I tried #1017) as well as the latest #1201.
Sample:
https://www.dropbox.com/s/6iuvgkm9zpd5iuu/00001.ts?dl=1
Why ssh combo root libreelec is not working
(2016-12-02, 12:30)Doktor-X Wrote: [ -> ]Why ssh combo root libreelec is not working
Works here. Can you describe in a little more detail what the problem is?
(2016-12-02, 15:15)Milhouse Wrote: [ -> ] (2016-12-02, 12:30)Doktor-X Wrote: [ -> ]Why ssh combo root libreelec is not working
SSH works here. Can you describe in a little more detail what the problem is?
SSH works fine here, also. VNC also works.
Is Amazon Prime supposed to work in build #1201? I get the following errors:
19:25:40.585 T:1961328640 WARNING: CDVDMessageQueue(player):
ut MSGQ_NOT_INITIALIZED
19:25:40.600 T:1528619936 NOTICE: Creating InputStream
19:25:41.038 T:1528619936 ERROR: AddOnLog: InputStream Adaptive: Unable to handle decryption. Unsupported!
19:25:41.038 T:1528619936 ERROR: CVideoPlayer::OpenInputStream - error opening
Mercifully, all other audio and video streaming works fine. I can play movies from my library, play music and stream TestTube, so the new streaming software does seem to work okay otherwise.
Also, unless I am missing something, the repositories appeared when I looked for them.
I notice that the splash screen still reads KODI 17 on startup. I imagine that is the least of your worries.
One other question. How secure is the password in the Amazon Prime apps? As recent events have shown, nothing is entirely secure but that would be an exceptionally bad password to have stolen.
(2016-12-02, 17:43)bill_orange Wrote: [ -> ]Is Amazon Prime supposed to work in build #1201? I get the following errors:
19:25:40.585 T:1961328640 WARNING: CDVDMessageQueue(player):ut MSGQ_NOT_INITIALIZED
Amazon Prime hasn't really worked for a month or two, since Amazon changed their encryption which broke inputstream.mpd playback of encrypted streams.
Decryption of Amazon streams remains a work in progress for Linux, and with the migration from inputstream.mpd/inputstream.smoothstream to inputstream.adaptive it remains a WIP for inputstream.adaptive, hence the errors you currently see with Amazon Prime.
Hopefully decryption support will be added to inputstream.adaptive in due course.
(2016-12-02, 17:43)bill_orange Wrote: [ -> ]One other question. How secure is the password in the Amazon Prime apps? As recent events have shown, nothing is entirely secure but that would be an exceptionally bad password to have stolen.
Without personally auditing the code I'm not in a position to say how secure it is. This is really a question for the add-on author to answer, and maybe requires independent review.
(2016-12-02, 01:03)Milhouse Wrote: [ -> ][*]Update hifiberry driver config
Any Hifiberry digi users? Can you confirm that passthrough is still working in this build?
I dont know how or why but now i can connect to pi without problem (maybe some cach problem)
New LibreELEC.tv Krypton build #1202:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.8.12 #1 Sat Dec 3 02:06:33 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Dec 1 2016 17:33:24
Copyright (c) 2012 Broadcom
version 0b89c6d8c5820e2b81576a7d2e80b93120fedd40 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161203020526-#1202-gdc3bd25 [Build #1202]
# Kodi version
(18.0-ALPHA1 Git:17.0-beta6-654f1b7). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (dc3bd252,
changelog) and tip of
XBMC master (d843051b,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.8.y
- Includes latest bcm2835-driver next (ba29d0a6, ahead +604)
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (209884d6)
- Includes latest libnfs master (a2b37349, ahead +2)
- Includes latest p8-platform master (2d90f986, ahead +9)
- Includes latest addons: inputstream.adaptive (4cfc3a29, +1), inputstream.rtmp (55437ac7), peripheral.joystick (d09e0c60), pvr.argustv (7d3bdba7), pvr.demo (9ebc62c6), pvr.dvblink (42207a03), pvr.dvbviewer (2449df9a), pvr.filmon (ca709b90), pvr.hdhomerun (ef45d3f7), pvr.hts (4f406f4c), pvr.iptvsimple (d69778ea), pvr.mediaportal.tvserver (8ba6a797), pvr.mythtv (b22cfa0e), pvr.nextpvr (fe85f2a3), pvr.njoy (3a322763), pvr.octonet (8549a31c), pvr.pctv (e829beb1), pvr.stalker (fd800fdb), pvr.vbox (4bc6f1e1), pvr.vdr.vnsi (4b06d83e), pvr.vuplus (d2c54427), pvr.wmc (bffb41d4)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: kodi: fix intel gpu detection patch after kodi/10848
- Include [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] PR:768: kodi use cmake
- Include [env] PR:805: merge /usr like it's 2012
- Include [env] PR:968: busybox: add getedid script
- Include [env] PR:997: xorg-server: add Synaptics driver if using evdev
- Include [env] PR:1014: mesa: add Apollo and Kaby Lake support to 7.90.009
- Include [pkg] PR:39: use prettyname_regex to show shortname in update menu (service.libreelec.settings)
- Include [pkg] PR:249: Fix ass_set_cache_limits() to work with composite cache (libass)
- Include [pkg] PR:11033: Fix game add-ons not loading
- Include [pkg] PR:11034: Savestate manager
Build Highlights:
- New 4.8.12 kernel
- Temporarily switch back to stock kodi-theme-Estuary
Build Details:
- LibreELEC.tv:
- linux: update to linux-4.8.12 (PR:1016, 3 commits, 28 files changed)
- alsa-lib: add HiFiBerry config (PR:1001, 1 commit, 2 files changed)
- XBMC:
- [cleanup][pvr] get rid of obsolete guide views (PR:10838, 2 commits, 5 files changed)
- [guilib] Change System.HasModalDialog to System.HasActiveModalDialog … (PR:10850, 2 commits, 11 files changed)
- Inconspicuous fix (PR:11022, 8 commits, 245 files changed)
- Mir windowing system for Kodi (PR:10898, 1 commit, 20 files changed)
- [PVR] context menu rewrite & major gui actions refactoring (PR:10870, 21 commits, 66 files changed)
- Integrate CSettings into CServiceManager/CServiceBroker (PR:10848, 3 commits, 223 files changed)
- [cmake] linux: install game headers (PR:11035, 1 commit, 1 file changed)
- fixed: do not use move into member variable here (PR:11026, 1 commit, 1 file changed)
- [Estouchy] update (PR:11030, 1 commit, 3 files changed)
- Revert "This makes the SubtitleDialog remember the last service used,… (PR:11036, 1 commit, 2 files changed)
- inputstream.adaptive:
- newclock5:
- Commits no longer in build:
- [hifiberry] Hack: force it to be recognised as IEC958 capable to enable passthrough options (e907db29)
- [rbp] [retroplayer] Initial support for mmal renderer (c55fcb77)
- Revert "[hifiberry] Hack: force it to be recognised as IEC958 capable to enable passthrough options" (e36ac2a4)
- kernel 4.8.y:
- New commits in this build:
- BCM2835 DT: Add DTC_FLAGS to support overlays (48c5b81e)
- Add overlays symlink and dtbo target for ARM64 (#1739) (ca6fb3c1)
- Added: [env] patch: kodi: fix intel gpu detection patch after kodi/10848
- Added: [env] PR:1014: mesa: add Apollo and Kaby Lake support to 7.90.009
- Added: [pkg] PR:11033: Fix game add-ons not loading
- Added: [pkg] PR:11034: Savestate manager
I must say i kind of like new estuary v2
(2016-12-02, 19:05)popcornmix Wrote: [ -> ] (2016-12-02, 01:03)Milhouse Wrote: [ -> ][*]Update hifiberry driver config
HifiBerryDigi is working fine on build #1203. No other issue so far.
Ollo thanks for the confirmation!
nothing out of the ordinary to report
fast reponding by chance the audiotrack on dvds ->top
hifiberry also works fine
a little: perhaps we will be able to chance the backround pattern in skin to dyed of one color (unicolor) ...dont like it ;-)
Silly question can you import video library from OSMC to LibreELE ?
(2016-12-03, 23:13)Rickt1962 Wrote: [ -> ]Silly question can you import video library from OSMC to LibreELE ?
I did with no problems, this is so much better than osmc as well, well worth the move.
Use the backup add-on, run a full backup, install libreelec, and then restore that backup, everything' should be the same as it was with osmc...
