Hi. I'm using netflix addon and for a minute or two it seems ok.but after that I'm experiencing buffering alot.
Is there any special configuration to the inputstream or anything else?
(2017-08-24, 09:32)HiassofT Wrote: [ -> ] (2017-08-23, 20:55)HiassofT Wrote: [ -> ] (2017-08-23, 19:02)dascoco Wrote: [ -> ]Is there already something new?
Not yet, the last few days I have been busy finding out why the tests I had planned you to run did crash the RPi2: https://github.com/raspberrypi/linux/issues/2166
Fortunately the underlying issue has just been resolved and I've PRed the changes that'll allow you to run the next tests. PR1917 should be included in the next milhouse build, if it is please do the following steps:
Add the following to the end of /flash/cmdline.txt:
trace_event=module:* ftrace=function ftrace_filter=__request_module
Your cmdline.txt should then look like this (everything must be in a single line):
boot=/dev/mmcblk0p1 disk=/dev/mmcblk0p2 quiet trace_event=module:* ftrace=function ftrace_filter=__request_module
Now power off the RPi, connect the HDD, power it up, then ssh in and post the outputs of these 2 commands:
dmesg | paste
cat /sys/kernel/debug/tracing/trace | paste
This should hopefully give us some more clues what's happening on your system.
so long,
Hias
Milhouse build 0823 contains the PR needed to run these tests. Can you give it a try?
It would also be good to know if you added some custom configuration (modprobe, systemd, udev etc). Please also post the output of the following command:
ls -lR /storage/.config /storage/.cache | paste
so long,
Hias
# dmesg | paste
http://sprunge.us/cRHj
# cat /sys/kernel/debug/tracing/trace | paste
http://sprunge.us/fcdg
# ls -lR /storage/.config /storage/.cache | paste
http://sprunge.us/KFdO
(2017-08-24, 18:05)dascoco Wrote: [ -> ] (2017-08-24, 09:32)HiassofT Wrote: [ -> ] (2017-08-23, 20:55)HiassofT Wrote: [ -> ]Not yet, the last few days I have been busy finding out why the tests I had planned you to run did crash the RPi2: https://github.com/raspberrypi/linux/issues/2166
dmesg | paste
so long,
Hias
so long,
Hias
# dmesg | paste
ftrace=function and ftrace_filter=__request_module are missing from your kernel command line:
[ 0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1440 bcm2708_fb.fbheight=900 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 boot=/dev/mmcblk0p1 disk=/dev/mmcblk0p2 quiet trace_event=module:* root=/dev/ram0 rdinit=/init BOOT_IMAGE=/kernel.img usbcore.autosuspend=-1
Could you setup cmdline.txt as described above and rerun the test?
so long,
Hias
New LibreELEC.tv Leia build #0824:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.12.8 #1 Thu Aug 24 21:58:07 BST 2017 armv6l GNU/Linux
# vcgencmd version
Aug 22 2017 14:20:40
Copyright (c) 2012 Broadcom
version eb51b8b84ec11d98562dfbb7be53cdd216c0ea4c (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20170824215656-#0824-gab9d8bf [Build #0824]
# Kodi version
(18.0-ALPHA1 Git:beb2913). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (ab9d8bf1,
changelog) and tip of
XBMC master (beb29133,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.12.y
- Includes latest bcm2835-driver master (8fe001ec, ahead +6)
- Includes latest kodi-platform master (36fb4937)
- Includes latest libcec master (8adc786b, ahead +26)
- Includes latest libnfs master (df94ae93, ahead +56)
- Includes latest p8-platform master (a822e196)
- Includes latest addons: inputstream.adaptive (be77f9f8, +55), inputstream.rtmp (e094fa38, +1), peripheral.joystick (cc14287c, +3), pvr.argustv (310737e2), pvr.demo (f07d898c, +1), pvr.dvblink (0b66c640, +4), pvr.dvbviewer (313339bf, +8), pvr.filmon (1c9d2ebe), pvr.hdhomerun (b89c2be4, +9), pvr.hts (a1de6329, +1), pvr.iptvsimple (260434e4, +5), pvr.mediaportal.tvserver (f5ee2000, +5), pvr.mythtv (a17a3a4f, +1), pvr.nextpvr (03a3b714), pvr.njoy (79e8e653), pvr.octonet (a77cf111), pvr.pctv (00b76689), pvr.stalker (df492d27, +1), pvr.vbox (44f3d04e), pvr.vdr.vnsi (07172ed0, +1), pvr.vuplus (921b14f6, +5), pvr.wmc (1d655540)
- Include [env] compare: kodi: updates for September
- Include [env] compare: brcmfmac_sdio-firmware-rpi: set BT MAC as new firmware uses a fixed MAC
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: tvheadend42: fixup ffmpeg patch
- Include [env] patch: tvheadend42: add bzip dependency when transcoding
- Include [env] patch: inputstream.adaptive: don't build it twice...
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] patch: pvr addons: disable broken addons
- Include [env] PR:1773: init: make break after behaviour really break after
- Include [env] PR:1776: Don't cause system to hang on halt/reboot when net-booting
- Include [env] PR:1791: nss/nspr: include in main image [rfc]
- Include [env] PR:1835: add support for optional kernel modules in image and from addons
- Include [env] PR:1876: linux: update to linux-4.12.8
- Include [env] PR:1915: xf86-video-nvidia: update to xf86-video-nvidia-384.69
- Include [env] PR:1917: linux: enable ftrace
- Include [env] PR:1918: Package Updates: intel-vaapi-driver, libva and libva-utils to 1.8.3
- Include [pkg] patch: Pre-release RPi0W/RPi3 Bluetooth firmware (details) (brcmfmac_sdio-firmware-rpi)
- Include [pkg] patch: Pre-release RPi0W/RPi3 WiFi firmware (details) (kernel-firmware)
- Include [pkg] patch: Pre-release RPi0W/RPi3 WiFi firmware (details) (wlan-firmware)
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:12311: FIX: ensure real filename from videodb in playlists
- Include [pkg] PR:12710: [DemuxClient] transport flags
Build Highlights:
- New 4.12.8 kernel
- inputstream.adaptive: add search list for libssd_wv.so
- inputstream.adaptive: sort impaired (audio description) streams last (ping @Pienoet)
- inputstream.adaptive: build improvements
Build Details:
- LibreELEC.tv:
- oscam: update to 11391 (PR:1912, 1 commit, 2 files changed)
- XBMC:
- [depends] bump libcdio-gplv3 to 0.94 (PR:12709, 1 commit, 2 files changed)
- Change search path logiv for decrypter (b856defb)
- Change search path logiv for decrypter (2) (5adc0312)
- [DASH] Support SegmentList in AdaptationSets (fd103b8c)
- New adaptationset sorting order (impaired last) (be77f9f8)
- kernel 4.12.y:
- Commits no longer in build:
- mm: Remove the PFN busy warning (857b93a8)
- Added: [env] patch: tvheadend42: add bzip dependency when transcoding
- Added: [env] patch: inputstream.adaptive: don't build it twice...
- Added: [env] PR:1876: linux: update to linux-4.12.8
- Added: [env] PR:1918: Package Updates: intel-vaapi-driver, libva and libva-utils to 1.8.3
- Added: [pkg] PR:12710: [DemuxClient] transport flags
(2017-08-24, 23:34)Milhouse Wrote: [ -> ]Build Highlights:
- New 4.12.8 kernel
Thank you Milhouse,
Installed #824 and the issue with the Audio Description in the netflix addon is fixed!
Thanks for pinging me!
Weekly Linux 4.13-rc6 build #0824x:
RPi /
RPi2
dascoco I found out why exfat didn't work, a fix for that should be in tonight's build. No need for any more logs, but please report back when the issue is fixed.
so long,
Hias
my ISP replaced a modem/router today which has caused all kinds of issues with my network, the least of which includes IP address changed everywhere.
My 2 RPI3s were up and running on new IPs, but my MySQL server IP changed, so I had to edit the advancedsettings.xml file through SSH. Upon reboot, neither RPi3 would boot into kodi, or if they did, all I get is a black screen. I don't see a crashlog from today, just an old one
http://sprunge.us/GZGK
Here is a debug log from build 0824 (both started on 0815, updated one as a test)
http://sprunge.us/gESK
Both have the same problem, on a reboot, I see the libreelec logo, a quick flash of the kodi logo, then a black screen, nothing more. Both are using a wireless connection too.
Wouldn't it have been easier to reconfigure your new router to use the same IP settings as your old router?
If Kodi is starting but hanging on a blank screen (and there is no crash log) then it's probably not crashing. You should be able to tell that by running "pgrep kodi.bin" over the course of a couple of minutes - if the number returned (the process id) is always the same then Kodi isn't crashing in a loop, it's just stuck.
Why is it stuck? Probably "wait for network" or some wake-on-lan configuration would be my guess. Maybe the MySQL server on "192.168.0.7" is not accessible?
(2017-08-25, 22:42)Milhouse Wrote: [ -> ]Wouldn't it have been easier to reconfigure your new router to use the same IP settings as your old router?
you would think so, but no. They provide a modem/router combo, the last one I was able to turn off DHCP and run it bridged so I could use my own wireless router as the DHCP server with all my settings/forwards for cameras etc. The new modem/router they provided is not allowing a bridged mode.
I reconfigured MySQL, that didn't help, I just updated MySQL and reconfigured, and that seems to have done the trick. Very odd indeed.
Well that didn't work either, I could see the MySQL library, but not play anything.
Turns out it appears the change in DHCP servers disabled network discovery on the WIN10 file server. Once that was re-enabled, I was able to play content.
New LibreELEC.tv Leia build #0825:
RPi /
RPi2
# uname -a
Linux rpi512 4.12.9 #1 Fri Aug 25 22:24:25 BST 2017 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20170825222320-#0825-g1ca3686 [Build #0825]
# Kodi version
(18.0-ALPHA1 Git:e35491d). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (1ca3686d,
XBMC master (e35491d8,
- Includes latest bcm2835-driver master (7f7df25d)
- Includes latest addons: inputstream.adaptive (be77f9f8, +55), inputstream.rtmp (e094fa38, +1), peripheral.joystick (cc14287c, +3), pvr.argustv (310737e2), pvr.demo (97d9462f, +2), pvr.dvblink (386088b5, +5), pvr.dvbviewer (d88ef8b3, +9), pvr.filmon (1c9d2ebe), pvr.hdhomerun (af02b933, +12), pvr.hts (ecab985b, +2), pvr.iptvsimple (1b803470, +6), pvr.mediaportal.tvserver (f327ab96, +6), pvr.mythtv (b46e5be2, +2), pvr.nextpvr (03a3b714), pvr.njoy (79e8e653), pvr.octonet (a77cf111), pvr.pctv (00b76689), pvr.stalker (df492d27, +1), pvr.vbox (44f3d04e), pvr.vdr.vnsi (7e6e3854, +2), pvr.vuplus (b8316b4c, +6), pvr.wmc (1d655540)
- Include [env] patch: samba: only hup if pid available
- Include [env] PR:1876: linux: update to linux-4.12.9
- Include [env] PR:1919: samba: don't restart smbd in samba-autoshare
- Include [env] PR:1922: brcmfmac_sdio-firmware-rpi: Consolidate firmware files
- Include [env] PR:1923: mesa: update to 17.2.0-rc5
Build Highlights:
- New 4.12.9 kernel
- Fix for FUSE when mounting exFAT
- Avoid restarting Samba when auto-sharing
- Consolidate RPi0W/RPi3 WiFI & BT firmware files - drop brcmfmac43430-sdio.{bin,txt} from non-RPi builds
- PVR Addon API 5.7.0: New functions for EPG tags
- pvr.octonet joins pvr.argustv/filmon/nextpvr/njoy/pctv/stalker/vbox/wmc on the "not building" step.
- omxplayer: Avoid hang when skipping to next video
Build Details:
- LibreELEC.tv:
- xf86-video-nvidia: update to xf86-video-nvidia-384.69 (PR:1915, 1 commit, 2 files changed)
- inadyn: update to 2.2 (PR:1894, 3 commits, 4 files changed)
- build system: drop .img extension for the open virtual appliance (PR:1893, 1 commit, 1 file changed)
- XBMC:
- Explicitly disable guile in GnuTLS build (PR:12638, 1 commit, 1 file changed)
- [PVR][addons][guiinfo][Estuary] PVR Addon API 5.7.0: New functions for EPG tags. (PR:12689, 6 commits, 35 files changed)
- FIX: [droid] update avail stream during state update (PR:12712, 1 commit, 1 file changed)
- Game OSD: New dialog for video settings (PR:12639, 13 commits, 51 files changed)
- pvr.demo:
- PVR API 5.7.0: Add IsEPGTagRecordable, IsEPGTagPlayable, GetEPGTagStr (PR:54, 1 commit, 3 files changed)
- pvr.dvblink:
- PVR API 5.7.0: Add IsEPGTagRecordable, IsEPGTagPlayable, GetEPGTagStr (PR:96, 1 commit, 4 files changed)
- pvr.dvbviewer:
- Final PVR API 5.7.0 (PR:69, 1 commit, 3 files changed)
- pvr.hdhomerun:
- update to PVR API 5.7.0 (PR:58, 1 commit, 4 files changed)
- Set libhdhomerun git tree to master (PR:59, 2 commits, 1 file changed)
- pvr.hts:
- PVR API 5.7.0: Add IsEPGTagRecordable, IsEPGTagPlayable, GetEPGTagStr (PR:324, 1 commit, 5 files changed)
- pvr.iptvsimple:
- PVR API 5.7.0: Add IsEPGTagRecordable, IsEPGTagPlayable, GetEPGTagStr (PR:155, 1 commit, 4 files changed)
- pvr.mediaportal.tvserver:
- PVR API 5.7.0: Add IsEPGTagRecordable, IsEPGTagPlayable, GetEPGTagStr (PR:75, 1 commit, 4 files changed)
- pvr.mythtv:
- PVR API 5.7.0: Add IsEPGTagRecordable, IsEPGTagPlayable, GetEPGTagStr (PR:83, 1 commit, 4 files changed)
- pvr.vdr.vnsi:
- PVR API 5.7.0: Add IsEPGTagRecordable, IsEPGTagPlayable, GetEPGTagStr (PR:8, 1 commit, 3 files changed)
- pvr.vuplus:
- PVR API 5.7.0: Add IsEPGTagRecordable, IsEPGTagPlayable, GetEPGTagStr (PR:73, 1 commit, 4 files changed)
- newclock5:
- New commits in this build:
- omxplayer: Avoid hang when skipping to next video (b9420679)
- kernel 4.12.y:
- mm: Remove the PFN busy warning (c87fbef6)
- cache: export clean and invalidate (48d090ab)
- vcsm: Provide new ioctl to clean/invalidate a 2D block (ef79e7bb)
- Updated: [env] patch: pvr addons: disable broken addons
- Added: [env] patch: samba: only hup if pid available
- Added: [env] PR:1919: samba: don't restart smbd in samba-autoshare
- Added: [env] PR:1922: brcmfmac_sdio-firmware-rpi: Consolidate firmware files
- Added: [env] PR:1923: mesa: update to 17.2.0-rc5
Slighty offtopic: I'd like to update my Pi2 via script, would it be possible to provide a static link which always points to the very latest release of yours?
Thank you!
regards
(2017-08-25, 14:24)HiassofT Wrote: [ -> ]@dascoco I found out why exfat didn't work, a fix for that should be in tonight's build. No need for any more logs, but please report back when the issue is fixed.
so long,
Hias
Now it's working well.
Thank you very much for solving this issue and invest much time on it.
(2017-08-24, 15:46)SpokV Wrote: [ -> ]Hi. I'm using netflix addon and for a minute or two it seems ok.but after that I'm experiencing buffering alot.
Although no one here responded just wanted to note that what solved my buffering issues was changing the advancedsettings format (changed on kodi 17).
(2017-08-26, 09:10)thent Wrote: [ -> ]Slighty offtopic: I'd like to update my Pi2 via script, would it be possible to provide a static link which always points to the very latest release of yours?
Thank you!
regards
Sorry, no. You could always parse the forum post - that's quite easily done in a shell script.
Or retrieve
http://milhouse.libreelec.tv/builds/mast...eases.json and determine the latest file from its contents.
