(2016-12-24, 15:26)MikeKL Wrote: [ -> ]HoHoHo, perhaps Father Christmas will pop down chimney tonight and re-add as user modifyable option to Estuary skin . Festive greetings to all, have a great break!
interface settings->skin->configure skin->artwork->choose background pattern
(2016-12-22, 17:03)popcornmix Wrote: [ -> ]@mikeb8591 can you test latest build without core_freq=400 in config.txt? Hopefully that will happen by magic on a Pi2 now as so not be required.
Confirmed. On #1221 my pi2 doesn't have video sync issues, and video is smooth with 'advanced' selected for deinterlace mode.
#1223 still has the issues I noted previously with the HDHomeRun View plugin, logo and buffering bar don't go away on live tv, and 'busy' icon never leaves.
Who maintains this plugin? (How do I find out who maintains it?)
Thanks! and Merry Christmas one and all.....
(2016-12-24, 21:30)mikeb8591 Wrote: [ -> ]#1223 still has the issues I noted previously with the HDHomeRun View plugin, logo and buffering bar don't go away on live tv, and 'busy' icon never leaves.
It might be worth starting a thread in the HDHomeRun support forum:
http://forum.kodi.tv/forumdisplay.php?fid=250
(2016-12-24, 21:30)mikeb8591 Wrote: [ -> ]Thanks! and Merry Christmas one and all.....
Merry Christmas everyone.
New LibreELEC.tv Krypton build #1224:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.9.0 #1 Sat Dec 24 21:06:58 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Dec 23 2016 16:46:02
Copyright (c) 2012 Broadcom
version 18a9fe64e58d73e303bf09b176fe63ddb7994a0c (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161224210557-#1224-gdc61a12 [Build #1224]
# Kodi version
(18.0-ALPHA1 Git:17.0-beta7-eed32e7). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (dc61a122,
changelog) and tip of
XBMC master (7b9b5122,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.9.y
- Includes latest bcm2835-driver next (da504fcd, ahead +610)
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (12fa2750, ahead +2)
- Includes latest libnfs master (a2b37349, ahead +2)
- Includes latest p8-platform master (2d90f986, ahead +9)
- Includes latest addons: inputstream.adaptive (fc862638), inputstream.rtmp (55437ac7), peripheral.joystick (987a818e), pvr.argustv (4702a9e7, +3), pvr.demo (99db6bf5, +3), pvr.dvblink (4e6992d9, +3), pvr.dvbviewer (2b8ab246, +12), pvr.filmon (a23db0c5, +3), pvr.hdhomerun (baeafbde, +3), pvr.hts (117d4020, +4), pvr.iptvsimple (df0649e7, +5), pvr.mediaportal.tvserver (f00ccfd3, +16), pvr.mythtv (41c3201f), pvr.nextpvr (48a7796a, +4), pvr.njoy (d1ad569b, +3), pvr.octonet (8549a31c), pvr.pctv (b8286a23, +3), pvr.stalker (dfda4c51, +3), pvr.vbox (bfa938c7, +9), pvr.vdr.vnsi (36023a36, +8), pvr.vuplus (acd75dc5, +3), pvr.wmc (35be514e, +3)
- Include [env] b0d8e331: kodi: alternative method to disable wiimote if bluetooth is disabled
- Include [env] da44aacf: TexturePacker: Hack to work around CMAKE_SOURCE_DIR
- Include [env] 4c39cc48: kodi: fix cmake after move to root
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: FFmpeg: Bump to final 3.1.6-Krypton
- Include [env] patch: kodi: fix intel gpu detection patch after kodi/10848
- Include [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
- Include [env] patch: repository.retroplayer.libreelec.addons: add temp repo for testing
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] PR:1025: scripts/create_addon: use PKG_REV as part of the binary addon version
- Include [env] PR:1052: Package updates
- Include [env] PR:1058: libdvbcsa: AArch64 support
- Include [env] PR:1067: vaapi hvec 10bit support
- Include [pkg] PR:249: Fix ass_set_cache_limits() to work with composite cache (libass)
- Include [pkg] PR:11163: Fix silent failure when game add-on can't be installed
- Include [pkg] PR:11225: [PVR] Fix crashes on pvr manager deinit/reinit - part 2 & 3
Build Highlights:
- Minors
Build Details:
- LibreELEC.tv:
- rpcbind: needs to wait until /var/run is available (PR:1090, 2 commits, 3 files changed)
- XBMC:
- [PVR] Fix guide window: do not jump to grid start on channel group change; go to 'now' instead (PR:11263, 1 commit, 2 files changed)
- MyGames: Remove duplicate add-on information context item (PR:11262, 1 commit, 2 files changed)
- [gui] fix crash when using container.property() in non-mediawindows (PR:11254, 2 commits, 1 file changed)
- pvr.vdr.vnsi:
- Added: [env] b0d8e331: kodi: alternative method to disable wiimote if bluetooth is disabled
There will be a build on the 25th (assuming there are no problems) however the changelog post will be delayed until the 26th.
(2016-12-24, 23:29)Milhouse Wrote: [ -> ]There will be a build on the 25th (assuming there are no problems) however the changelog post will be delayed until the 26th.
Thank You and Merry Christmas..
All the best for 2017..
(2016-12-24, 22:14)Milhouse Wrote: [ -> ]It might be worth starting a thread in the HDHomeRun support forum: http://forum.kodi.tv/forumdisplay.php?fid=250
I need to get out more, I didn't realize that there was a HDHR Kodi forum.
Thanks for the pointer, and for all the work you put into doing these builds!
call me nuts but I like the concrete color scheme.
Merry Christmas !
(2016-12-25, 13:32)tuxen Wrote: [ -> ]call me nuts but I like the concrete color scheme.
At least one is using my color scheme
is there another way to wake up kodi from it's dimmed state other than reboot from terminal or unplugging power? this mostly happens after I switch to another input on my av receiver (eg play wii or ps3) and come back to the kodi hdmi after a while, kodi will then be dimmed and won't react to any key from the remote.
(2016-12-26, 19:43)nuwonda Wrote: [ -> ]is there another way to wake up kodi from it's dimmed state other than reboot from terminal or unplugging power? this mostly happens after I switch to another input on my av receiver (eg play wii or ps3) and come back to the kodi hdmi after a while, kodi will then be dimmed and won't react to any key from the remote.
Is this a CEC issue?
Can you test if it works with a USB keyboard or phone remote?
(2016-12-26, 22:30)popcornmix Wrote: [ -> ] (2016-12-26, 19:43)nuwonda Wrote: [ -> ]is there another way to wake up kodi from it's dimmed state other than reboot from terminal or unplugging power? this mostly happens after I switch to another input on my av receiver (eg play wii or ps3) and come back to the kodi hdmi after a while, kodi will then be dimmed and won't react to any key from the remote.
I've found that it takes at least 5 key presses from my remote to wake up the pi when in this dimmed state, whereas one key press from a usb keyboard will wake it up.
(2016-12-26, 19:23)da-anda Wrote: [ -> ] (2016-12-25, 13:32)tuxen Wrote: [ -> ]call me nuts but I like the concrete color scheme.
LOL! I use it as well [emoji6] [emoji106]
Skickat från min HTC 10 via Tapatalk
