(2017-10-06, 21:23)Milhouse Wrote: [ -> ]Those with missing labels in #1005, are you using any Game related addons? There wasn't much added in #1005, and it's working fine for me...
The logs and pics were from a clean .kodi folder, nothing installed at all.
Regards
Bucky
Sorry didnt read that you'd already found the problem..
New LibreELEC.tv Leia build #1006:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.13.5 #1 Fri Oct 6 21:51:58 BST 2017 armv6l GNU/Linux
# vcgencmd version
Oct 6 2017 13:59:43
Copyright (c) 2012 Broadcom
version bde38f02b236b6e1bd16eb0f9b44b35f5a85cb30 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20171006215044-#1006-g70512c3 [Build #1006]
# Kodi version
(18.0-ALPHA1 Git:d18acce). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (70512c3,
changelog) and tip of
XBMC master (d18acce,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.13.y
- Includes latest bcm2835-driver master (2669578, ahead +1)
- Includes latest kodi-platform master (36fb493)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (2911afe, ahead +103)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (dde3921), inputstream.rtmp (26260c9), peripheral.joystick (cc14287), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (9765663, +1), pvr.filmon (7a9af25, +1), pvr.hdhomerun (ddfe2cb, +1), pvr.hts (1763251, +12), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (fa1069d, +1), pvr.mythtv (8965048), pvr.nextpvr (5b7caa2, +1), pvr.njoy (cc1cb56), pvr.octonet (e9b4c05), pvr.pctv (549f690), pvr.stalker (e15edca), pvr.teleboy (1cf8e96, +2), pvr.vbox (56052da, +1), pvr.vdr.vnsi (f3f80d5), pvr.vuplus (c53478d, +1), pvr.wmc (02edba6, +1), pvr.zattoo (73009cd)
- Include [env] compare: dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: tvheadend42: fix makefile patch
- Include [env] patch: media_build: disable due to conflicts
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] patch: pvr addons: disable broken addons
- Include [env] PR:1776: Don't cause system to hang on halt/reboot when net-booting
- Include [env] PR:1791: nss/nspr: include in main image [rfc]
- Include [env] PR:1835: add support for optional kernel modules in image and from addons
- Include [env] PR:1978: linux: update to linux-4.13.4
- Include [env] PR:2002: linux: include HBR and ELD fixes for Intel
- Include [env] PR:2048: mesa: update to 17.2.2
- Include [env] PR:2061: added EFI 32bit support via GRUB2
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:234: implement intensity compensation for VC-1 decoding for Ivybridge and better (intel-vaapi-driver)
- Include [pkg] PR:260: Fix Seeking with VC1 after 6702b01ee3598017f05374bfc7956493f790361c (intel-vaapi-driver)
Build Highlights:
- New 4.13.5 kernel
- Disabled media_build due to conflicts (@polo_joe any better?)
- Missing labels not yet fixed - allow Dim screensaver to start as temporary fix
Build Details:
- LibreELEC.tv:
- eventlircd: switch to LibreELEC repo (PR:2069, 1 commit, 1 file changed)
- imx6: update config for Linux 3.14 (PR:2064, 1 commit, 1 file changed)
- imx6: update Realtek wifi patches for Linux 3.14 (PR:2063, 1 commit, 2 files changed)
- Fix installation to internal storage on top of Android Marshmallow on WeTek Hub and WeTek Play 2 (PR:2071, 4 commits, 4 files changed)
- XBMC:
- add additional binary support to BUILD_DIR support in addon helper (PR:12881, 1 commit, 1 file changed)
- AESinkPULSE: Allow pulseaudio 11 new option remixing-use-all-sink-channels=no (PR:12874, 1 commit, 1 file changed)
- Fix black screen on Snes9x emulators when ROM is missing (PR:12882, 1 commit, 2 files changed)
- pvr.teleboy:
- Add HTML body to debug in case login fails (df0aa7d)
- Fix login for free accounts (1cf8e96)
- Added: [env] patch: media_build: disable due to conflicts
Latest build works for me beside labels issue.
Thanks @
Milhouse
I have a problem that the memory about every 2 days to 90%, then he always depends on! Current version 1003
(2017-10-07, 05:29)ManiacKill Wrote: [ -> ]Hi,
How are you determining that 90% of memory is being used? Note that Linux will use all free memory as a file cache so memory being used isn't necessarily a problem. When an application needs more memory then Linux will stop using it as file cache and release it to the application.
If you are saying you haven an actual problem, ie. Kodi is crashing due to out of memory, then when did this start? What addons do you have installed (are you using a PVR addon, which one)? Have you tried a "clean" Kodi install to rule out a rogue addon?
I have the VU + / Enigma2 Client active, Amazon, Dazn, SkyGo, NBA League Pass, Rhapsody, xStream, YouTube, LoadShip.Hab not yet reinstallation because the problem with 4 devices is!
What is still active is the Unary Clock Screensaver.
(2017-10-07, 00:28)polo_joe Wrote: [ -> ]Latest build works for me beside labels issue.
Thanks @Milhouse
Hi, 1005 and 1006 still give me missing labels. After several minutes it seems that on 1006 they somehow do appear. As the family can not wait for that I reverted to 1004. No game related adons or anything.
Thx for all the good work.
ManiacKill unfortunately you still haven't explained what the problem is - I'm only able to guess at this stage.
(2017-10-07, 13:18)Huey Wrote: [ -> ]Hi, 1005 and 1006 still give me missing labels. After several minutes it seems that on 1006 they somehow do appear. As the family can not wait for that I reverted to 1004. No game related adons or anything.
Yes, they appear once the Dim screensaver has kicked in. The problem will be fixed in tonight's #1007 build.
since a few updates in the past my hyperion isn't working anymore ...
i can set color only if i not choose complet at the wheelcolor outer end ... any ideas? nothing changed at my config
OK Stop, with 1004 it's working again
pyrodex
Run:
texturecache.py Jd tvshows halt @extrajson.tvshows.episode=playcount | pastebinit
and paste the link.
I'm fairly sure that Kodi is treating Season 4 Episode 6 as watched, because the playcount is not zero.
I can reproduce what you are seeing if I set the playcount of a partially watched episode to 1:
texturecache.py set episode 20334 playcount 1
where 20334 is the episode id of the partially watched episode (the episode id for S04E6 in your case).
If you set the playcount to 0 for episode S04E06 then you should see it now listed in the Unwatched filter. Or you can use the episode context menu and "Mark as unwatched" which should achieve the same effect.
This
Wiki page explains when Kodi marks a video as watched.
Did you mention you only see this with these builds and not a Mac (or something)? If so I have no idea why that would be, unless the other devices are not sharing the same database. You can query the playcount on those other machines to confirm their playcount is zero as the filter is making decisions based only on the metadata in the video library.
Every time I start a movie the memory increases. Sometimes I have so 55% and the next day 85% memory leak!
(2017-10-07, 18:22)ManiacKill Wrote: [ -> ]Every time I start a movie the memory increases. Sometimes I have so 55% and the next day 85% memory leak!
Test a "clean" system, please.
I'd updated today from 0922 to the latest build. After this, I haven't any labeling anymore in Kodi UI
