re 3D - as mentioned some posts earlier, one specific method that triggers the StereoScopicsManager with all it's logic still needs to be re-implemented after the refactoring done in VideoPlayer. I'm unfortunately still too busy in real life in order to fix it. So if nobody else is working on it, it might stay broken for a couple more days.
Are the Movie and TV categories for the Estuary skin modifications meant to work with these builds, as mine do not change to select the categories when trying to customise them..?
Not sure if to report this in the Estuary forum unless this is related to these builds.
@garbear: I didn't write a bug ticket for the ps3 multi controller assignment bug, since this was kernel related. I reported it around July. The other bug reports I wrote are still present but surely will be fixed with your player manager - I will test then!
(2017-12-18, 21:36)linkinsoldier Wrote: [ -> ]@garbear: I didn't write a bug ticket for the ps3 multi controller assignment bug, since this was kernel related. I reported it around July. The other bug reports I wrote are still present but surely will be fixed with your player manager - I will test then!
Ah I see, I missed your issue in my list of controller bugs:
https://github.com/garbear/xbmc/issues/79 . I'll check it off. Thanks!
(2017-12-17, 12:49)-DH- Wrote: [ -> ]Well, "3D not working" ... let's a little more specific on this issue. ;-)
Current version is #1216 on RPi3, I use only .MKV and .ISO files for testing (the samples provided at http://kodi.wiki/view/Samples).
My results so far:
ISO-full3D-sample.iso (plays 3D)
HSDB-3D.mkv (plays 3D)
HTAB-3D.mkv (plays 2D)
3D-full-MVC.mkv (plays 2D)
Renaming the non-working MKV files according the video naming rules (http://kodi.wiki/view/3D) didn't change anything.
So what's the difference of these three .MKV files above:
The working MKV file's video stream has set the flag "Video stereo mode" to "1", meaning side by side/left eye first,
but for the other two files there was nothing.
So I changed both file's video stream flags (using mkvtoolnix/header editor on Windows):
HTAB-3D.mkv - "Video stereo mode" to "3" (top bottom/left eye first)
3D-full-MVC.mkv - "Video stereo mode" to "13" (both eyes laced in one block/left eye first)
... and that fixed it.
So on my end 3D MVC .iso playback is working as usual but all 3D .mkv's need to be tagged properly.
But...mkvs had been always tagged properply since they used to work.
I just played that very same 3d-full-mvc.mkv demo file on Krypton, no need to change anything on the mkv file.
Also i played *.3d.mvc.m2ts while this did not work on Kodi´s current version.
(2017-12-18, 19:32)da-anda Wrote: [ -> ]re 3D - as mentioned some posts earlier, one specific method that triggers the StereoScopicsManager with all it's logic still needs to be re-implemented after the refactoring done in VideoPlayer. I'm unfortunately still too busy in real life in order to fix it. So if nobody else is working on it, it might stay broken for a couple more days.
We had been waiting some time already, so there is no problem on waiting a bit longer.
Very much appreciated if you can fix it at some point.
(2017-12-18, 20:37)Vimes Wrote: [ -> ]Are the Movie and TV categories for the Estuary skin modifications meant to work with these builds, as mine do not change to select the categories when trying to customise them..?
Can you be more specific what isn't working, and if you are using stock Estuary or a third party skin (if the latter, report it in the skin thread).
New LibreELEC.tv Leia build #1218:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
33c5c726f07bee07d6c5f1d9df1520179b4d573956115b0647515a61073ad6fa (RPi)
SHA256 Checksum:
dff77febef339677fc382856a5f025f477a12869e00e0ab6a6b015549ed430f6 (RPi2)
# uname -a
Linux rpi512 4.14.7 #1 Tue Dec 19 03:59:52 GMT 2017 armv6l GNU/Linux
# vcgencmd version
Dec 1 2017 16:20:32
Copyright (c) 2012 Broadcom
version 38ac72569d7fbd7cf75754d9f14c2495416aaee7 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20171219035841-#1218-g31a943b [Build #1218]
# Kodi version
(18.0-ALPHA1 Git:71a7780). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (31a943b,
changelog) and tip of
XBMC master (71a7780,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.14.y
- Includes latest bcm2835-driver master (f22c4b5, ahead +9)
- Includes latest kodi-platform master (36fb493)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (82b3411, ahead +109)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (564981a, +2), inputstream.rtmp (c772497), peripheral.joystick (33b43ce), pvr.argustv (1aa4ddc, +1), pvr.demo (744d8ef, +1), pvr.dvblink (4ac2f2d, +1), pvr.dvbviewer (c2275e1, +1), pvr.filmon (17e8193, +1), pvr.hdhomerun (8b931e8, +2), pvr.hts (2f39155, +1), pvr.iptvsimple (53f94ec, +1), pvr.mediaportal.tvserver (8f11874, +1), pvr.mythtv (8f214cd), pvr.nextpvr (11dfdbb, +1), pvr.njoy (f7a9913, +1), pvr.octonet (c4af00a), pvr.pctv (7b1c634, +1), pvr.stalker (fad6ed4, +2), pvr.teleboy (e431126), pvr.vbox (1ed3fd2, +1), pvr.vdr.vnsi (0ec3e77), pvr.vuplus (b090f73, +1), pvr.wmc (920ade6, +1), pvr.zattoo (23d9993), vfs.libarchive (568a2a1)
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: fix PR390
- Include [env] patch: samba: Fix linking issues
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2243 (perma): NOOBS: shorten partition labels, add $DEVICE support
- Include [env] PR:2298 (perma): Kodi updates for Jan 2018
- Include [env] PR:2317 (perma): linux: update to linux-4.14.8
- Include [env] PR:2323 (perma): buildsystem: source functions earlier, validate project/arch earlier, refactor show_config
- Include [env] PR:2329 (perma): passthrough: drop kernel patch, force full
- Include [env] PR:2331 (perma): systemd: update to 236
- Include [pkg] patch: ##lan78xx: disable WOL (linux)
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:55 (perma): Fix deprecated function warnings (pvr.pctv)
- Include [pkg] PR:80 (perma): update jsoncpp methods to non deprecated versions (pvr.filmon)
- Include [pkg] PR:103 (perma): jsoncpp deprecated function change (pvr.stalker)
- Include [pkg] PR:13034 (perma): Cmake cpp14
- Include [pkg] PR:13062 (perma): smbclient changes for smb minprotocol and legacysecurity
Build Highlights:
- New 4.14.7 kernel
- Update to systemd-236
Build Details:
- LibreELEC.tv:
- Updates for S905 (PR:2319, 22 commits, 51 files changed)
- wayland support (PR:2232, 17 commits, 22 files changed)
- XBMC:
- AESinkPULSE: Check if module-allow-passthrough is loaded and warn if not available (PR:13210, 2 commits, 1 file changed)
- fixed: the JobManager.Add/CancelJob tests are racy (PR:13212, 1 commit, 1 file changed)
- [win32] Fix missing window icon on switching from fullscreen mode (PR:13209, 1 commit, 1 file changed)
- Wayland: Fix VAAPIRegisterRender implementation when vaapi disabled (PR:13214, 1 commit, 1 file changed)
- remove old ThumbnailCache.cpp/h (PR:13215, 1 commit, 3 files changed)
- inputstream.adaptive:
- Fix segmentNumber based live streams (seg_start -> seg_end) (564981a)
- pvr.stalker:
- [win10][depends] libxml2: fix deprecated uwp api (PR:104, 1 commit, 5 files changed)
- newclock5:
- Commits no longer in build:
- DemuxMVC: Fixup after Reset change (ac784af6)
- fixups after linux platform change (566579c1)
- Updated: [env] PR:2317 (perma): linux: update to linux-4.14.8
- Updated: [env] PR:2323 (perma): buildsystem: source functions earlier, validate project/arch earlier, refactor show_config
- Added: [env] patch: samba: Fix linking issues
- Added: [env] PR:2331 (perma): systemd: update to 236
(2017-12-19, 05:49)Milhouse Wrote: [ -> ] (2017-12-18, 20:37)Vimes Wrote: [ -> ]re the Movie and TV categories for the Estuary skin modifications meant to work with these builds, as mine do not change to select the categories when trying to customise them..?
Hi
I am using the stock Estuary skin.
The function is highlighted here....
you can see the function to edit categories and yet when selected nothing happens. Am I right to assume, for example, I should be able to edit items such as "recently added movies" to display or not....? If so that function does nothing when selected and pressed, for either movies or any other menu item listed.
(2017-12-19, 11:29)Vimes Wrote: [ -> ]you can see the function to edit categories and yet when selected nothing happens. Am I right to assume, for example, I should be able to edit items such as "recently added movies" to display or not....? If so that function does nothing when selected and pressed, for either movies or any other menu item listed.
Can you confirm that Library Node Editor is enabled? If not, enable it.
(2017-12-19, 19:10)Milhouse Wrote: [ -> ] (2017-12-19, 11:29)Vimes Wrote: [ -> ]you can see the function to edit categories and yet when selected nothing happens. Am I right to assume, for example, I should be able to edit items such as "recently added movies" to display or not....? If so that function does nothing when selected and pressed, for either movies or any other menu item listed.
I would like to tell you why it was disabled, the library node editor, but I didn't know that it existed.
What I now know is that after I enabled it I now have the ability to edit those categories.
Many thanks
Just wanted to know if there is already anything new about the issue in
DVD Playback
After I trying it several times it works with the same DVD, as soon I restart the Pi problem occurs again
New LibreELEC.tv Leia build #1219:
RPi /
RPi2
SHA256 Checksum:
1dd93ef7e1deef8419cfa8dfb61d092defd3a1046cfc0ff687ce5f79c094afc8 (RPi)
SHA256 Checksum:
904331a30379989261d95aaf95fbe6c7b2ea4e9753fb231e1313051672863c12 (RPi2)
# uname -a
Linux rpi512 4.14.7 #1 Wed Dec 20 08:54:13 GMT 2017 armv6l GNU/Linux
# vcgencmd version
Dec 1 2017 16:20:32
# lsb_release
LibreELEC (Milhouse): devel-20171220085302-#1219-gd63f060 [Build #1219]
# Kodi version
(18.0-ALPHA1 Git:7b1ff23). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (d63f060,
XBMC master (7b1ff23,
- Includes latest bcm2835-driver master (dadde5e, ahead +10)
- Includes latest addons: inputstream.adaptive (564981a), inputstream.rtmp (c772497), peripheral.joystick (33b43ce), pvr.argustv (1aa4ddc), pvr.demo (744d8ef), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (17e8193), pvr.hdhomerun (8b931e8), pvr.hts (2f39155), pvr.iptvsimple (53f94ec), pvr.mediaportal.tvserver (8f11874), pvr.mythtv (8f214cd), pvr.nextpvr (11dfdbb), pvr.njoy (f7a9913), pvr.octonet (c4af00a), pvr.pctv (7b1c634), pvr.stalker (fad6ed4), pvr.teleboy (e431126), pvr.vbox (1ed3fd2), pvr.vdr.vnsi (0ec3e77), pvr.vuplus (b090f73), pvr.wmc (920ade6), pvr.zattoo (23d9993), vfs.libarchive (568a2a1)
Build Highlights:
- VideoPlayer: Fix stereo mode detection from filename in GetVideoStreamInfo
- [PVR] Fix CPVREpgContainer::CreateChannelEpg not to change channel's
Build Details:
- LibreELEC.tv:
- projects/S905: enable hw decoding in kernel config (PR:2337, 3 commits, 3 files changed)
- samba: fix link issues when rebuilding (PR:2338, 1 commit, 1 file changed)
- chromium: security fix to 63.0.3239.108 (PR:2333, 1 commit, 2 files changed)
- adafruit-libraries: 2 updates (PR:2339, 1 commit, 4 files changed)
- XBMC:
- [Win10] fix windows store certification errors. (PR:13211, 3 commits, 7 files changed)
- Dvd autoplay during active player (PR:13142, 1 commit, 1 file changed)
- [PVR] Fix CPVREpgContainer::CreateChannelEpg not to change channel's (PR:13216, 1 commit, 1 file changed)
- [cleanup] windows doesn't use GL anymore (PR:13217, 1 commit, 1 file changed)
- [Windows] Fix BuildSetup.bat after #13211 (PR:13218, 2 commits, 3 files changed)
- kill g_powerManager global (PR:13190, 3 commits, 13 files changed)
- [cmake] remove force disabling vaapi for gbm (PR:13220, 1 commit, 1 file changed)
- Remove Travis badge, update Kodi banner image URL (PR:13204, 0 commits, 0 files changed)
- newclock5:
- New commits in this build:
- ServiceBroker: add CPowerManager (17c2fc5f)
- kill g_powerManager (9fdf683d)
- fix includes after killing g_powerManager (af240f62)
- VideoPlayer: Fix stereo mode detection from filename in GetVideoStreamInfo (eaacface)
- Updated: [env] PR:2298 (perma): Kodi updates for Jan 2018
Weekly Linux 4.15-rc4 build #1219x:
RPi /
RPi2
Packages disabled/not included:
RTL8192CU
RTL8192DU
RTL8192EU
RTL8812AU
DVB Driver Addons
Packages added/updated:
Known issues:
wireless-regdb is not working - needs upstream fix
