Hello everybody,
I've a question for the pros
When I remove a serie from kodi, it remove all files and the folder (exactly what I want).
But if I remove a film, it leaves somes files and the folder.
So my (maybe dumb) question is :
is it normal to have two different results from the same action depending on where you do it ?
Regards.
(sorry to bother you with a non raspberry related question
Using LibreElec 8.2.2 with Transparency on Intel Nuc (same behavior with estuary)
First of all, thanks for your work! I will receive my new raspberry soon, and I have a small question:
I am interested in the retroplayer option in Leia and was wondering if, in its current stage, it is usable or not stable enough to enjoy it? I don't see much feedback about it there.
For the moment I used the stable 8.2.2 on raspberry 2 and I am so happy with it.
(2018-01-11, 08:50)ksooo Wrote: [ -> ] (2018-01-10, 21:43)doug Wrote: [ -> ]Okay, here's an actual crashlog from a debug build with the "random" crash at night:
https://drive.google.com/file/d/1kXW4dbp...sp=sharing
Hopefully it has something in there that is useful.
Nope. No useable stack trace from crashing thread in there.
I changed the power supply and got a new crash this night:
http://ix.io/E1N
4ndreas
(2018-01-10, 21:42)noidea Wrote: [ -> ] (2018-01-10, 19:39)alannmills Wrote: [ -> ] (2018-01-10, 19:25)tehnatural Wrote: [ -> ] @alannmills I was having a similar issue where my sound would not play on certain videos. I found that enabling the option to adjust the display refresh rate to match the video 'fixed' the problem for me.
Thanks for the suggestion. I believe this is a different issue. It works on previous build, and is now broken. The same issue exists with music (mp3)and LiveTV, so is more audio based than video based if that makes sense.
I have the same issue, you can "enable" the sound it you change the volume in kodi while the movie etc. is playing. You have to do it everytime you play a new file. I also reverted back to the #0104 version.
Here is a link to a log from 0104. This one works correctly.
http://ix.io/E1F
Milhouse, is there anything else that I can provide?
(2018-01-11, 02:39)Milhouse Wrote: [ -> ] (2018-01-11, 02:33)tjost Wrote: [ -> ]Live TV, Movies, and Streams (DAZN) working o.k. but as soon as I open a menu the movie starts to stutter awful.
i do not have a crash log because it is not a crash.
Then provide a debug log. No debug log, no issue.
(2018-01-11, 02:33)tjost Wrote: [ -> ]but I gets a bit better.
Knowing when the first build when this stutter issue started would be useful.
(2018-01-11, 02:33)tjost Wrote: [ -> ]maybe you try a new linux kernel. a Beta version?
Sure, you can try a 4.15-rc kernel.
https://github.com/LibreELEC/LibreELEC.tv/pull/2275
as I mentioned before it startet with LibreELEC 9 first version
i tried the 4.15-rc kernel and on this build my SSD1306 OLED Display Add-on doesn't work so I skipped this build.
i didn't get a result from "cat /storage/.kodi/temp/kodi.log | pastebinit" so I copied it on my server.
log
(2018-01-11, 20:13)alannmills Wrote: [ -> ]@Milhouse, is there anything else that I can provide?
Not as far as I can tell. I don't know what the issue is, but hopefully someone else does.
(2018-01-11, 22:16)tjost Wrote: [ -> ]as I mentioned before it startet with LibreELEC 9 first version
I can't seem to find the post when you mentioned this, can you provide the link in case it includes other useful information?
So you're saying this issue started over 12 months ago? Can you test the final LE8 test builds, prior to the switch to LE9? I'm surprised others aren't reporting this.
New LibreELEC.tv Leia build #0111:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
7e02d32c964ed6f61f4a7a516b4dff0d6db740c9b1dc40dc0b7aaf470bf5aef7
(RPi)
SHA256 Checksum:
008760d681bb32d4fb7ed4fe4519add83f6acf2d778c952f7d48546bde9d3c94
(RPi2)
text:
# uname -a
Linux rpi512 4.14.13 #1 Thu Jan 11 22:05:09 GMT 2018 armv6l GNU/Linux
# vcgencmd version
Jan 11 2018 19:25:00
Copyright © 2012 Broadcom
version 0deb3d4e5956807bc641565696eeace31e3903c0 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20180111220352-#0111-g883f1ba [Build #0111]
# Kodi version
(18.0-ALPHA1 Git:138fa39). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (883f1ba,
changelog) and tip of
XBMC master (4e01f3d,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.14.y
- Includes latest bcm2835-driver master (e5f6f31, ahead +1)
- Includes latest kodi-platform master (36fb493)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (4dda1f8, ahead +114)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (fb0ca21), inputstream.rtmp (482f5c1), peripheral.joystick (3a93486), pvr.argustv (a4d3ec7), pvr.demo (0224cbd, +1), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (e5e89b1, +5), pvr.iptvsimple (a768d0e), pvr.mediaportal.tvserver (dcf0512), pvr.mythtv (cab8839), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (c4af00a), pvr.pctv (c7a13d7), pvr.stalker (c91421d), pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (4db947c, +2), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (4940bcc), vfs.libarchive (568a2a1)
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: fix PR390
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2243 (perma): NOOBS: shorten partition labels, add $DEVICE support
- Include [env] PR:2378 (perma): moonlight: update to moonlight-4d94439
- Include [env] PR:2382 (perma): linux: DVB fixes
- Include [env] PR:2384 (perma): kodi: updates for Feb 2018
- Include [env] PR:2392 (perma): linux: update to linux-4.14.15 (-ish)
- Include [env] PR:2409 (perma): samba: use documented browseable/writeable properties not synonyms
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:13274 (perma): Mode whitelist
Build Highlights:
- New firmware
- [fix] boolean condition window.is does not work properly
Build Details:
- Firmware (Jan 11):
- firmware: arm_loader: Make program_usb_boot_mode more flexible
- firmware: ov5647: Comment Y offset in mode 5 (2x2 binned 16:9)
- firmware: Video encode: Add option to set number of droppable P frames. See: link
- XBMC:
- [fix] boolean condition window.is does not work properly (PR:13346, 1 commit, 1 file changed)
- [droid] switch to jni for json and bitmaps (PR:13331, 4 commits, 15 files changed)
- [depends] bump python27 to 2.7.14 (PR:13328, 4 commits, 13 files changed)
- Update RetroPlayer's Render Manager documentation (PR:13341, 2 commits, 3 files changed)
- RendererDRMPRIME: add atomic support (PR:13192, 4 commits, 11 files changed)
- [xbmc][win32] First step in supporting VS2017 (PR:13279, 1 commit, 25 files changed)
- pvr.vdr.vnsi:
- fix osd for legacy OpenGL (4db947c)
- newclock5:
- New commits in this build:
- Revert "[bluray] Update libbluray to version 1.0.2." (8fa588c4)
- Updated: [env] PR:2392 (perma): linux: update to linux-4.14.15 (-ish)
- Added: [env] PR:2409 (perma): samba: use documented browseable/writeable properties not synonyms
(2018-01-11, 23:21)Milhouse Wrote: [ -> ] (2018-01-11, 20:13)alannmills Wrote: [ -> ]@Milhouse, is there anything else that I can provide?
Perhaps it is something to do with this?
Bad debug log
DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_mixer input port 232 output port 231 m_handle 0x599f0ea0
DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_render input port 100 output port 100 m_handle 0x68166f98
INFO: COMXAudio::ApplyVolume -
Volume=0.00 (* 1.00 * 1.00)
Good debug log
DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_mixer input port 232 output port 231 m_handle 0x3ab8590
DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_render input port 100 output port 100 m_handle 0x3dc2028
INFO: COMXAudio::ApplyVolume - Volume=1.00 (* 1.00 * 1.00)
As someone suggested earlier, that when playing the video, you could change volume within the settings?
What ive seen while using omx on the latest builds is the volume seems to be muted when media starts, one press on the volume up button and the sound returns.
Regards Bucky.
(2018-01-12, 10:40)bmonster Wrote: [ -> ]Hi,
Regards Bucky.
Yes, I can confirm this is an OMX issue - with OMX disabled/MMAL enabled there is no problem. And it does start with #0105.
with the build #0111 no more dropping sound in videoplayer, just OMXplayer still with the mute sound at the start
(2018-01-12, 22:27)germa18 Wrote: [ -> ]with the build #0111 no more dropping sound in videoplayer, just OMXplayer still with the mute sound at the start
omxplayer will be fixed tonight in #0112 (thanks all who reported, and @
popcornmix for fixing).
New LibreELEC.tv Leia build #0112:
RPi /
RPi2
SHA256 Checksum:
43d2a183badf91501bb8688534929fa31456dd78e72a5a03bad7cc8a02aea394
(RPi)
SHA256 Checksum:
83cfa39508171ea896ff915afcd377059f23fb754d750f6e269025f6cb1557f8
(RPi2)
text:
# uname -a
Linux rpi512 4.14.13 #1 Fri Jan 12 21:04:19 GMT 2018 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20180112210307-#0112-gc76dba0 [Build #0112]
# Kodi version
Based on tip of
LibreELEC.tv master (c76dba0,
XBMC master (863266b,
- Includes latest addons: inputstream.adaptive (fb0ca21), inputstream.rtmp (482f5c1), peripheral.joystick (3a93486), pvr.argustv (a4d3ec7), pvr.demo (0224cbd, +1), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (e5e89b1, +5), pvr.iptvsimple (a768d0e), pvr.mediaportal.tvserver (dcf0512), pvr.mythtv (3200b09, +1), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (c4af00a), pvr.pctv (c7a13d7), pvr.stalker (c91421d), pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (4db947c, +2), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (4940bcc), vfs.libarchive (568a2a1)
- Include [env] PR:2410 (perma): mesa/xf86-video-intel: bump to 17.3.2/028c946
Build Highlights:
- Application: Set volume after opening file
- [gui] refactor window is topmost methods and add new boolean conditions
- [xbmc][improvement] Add a platform abstraction for temp files / directories
Build Details:
- LibreELEC.tv:
- samba: use documented browseable/writeable properties not synonyms (PR:2409, 2 commits, 2 files changed)
- XBMC:
- [gui] refactor window is topmost methods and add new boolean conditions (PR:13348, 7 commits, 11 files changed)
- [xbmc][improvement] Add a platform abstraction for temp files / directories (PR:13253, 1 commit, 9 files changed)
- pvr.mythtv:
- fill major and minor number for channel in group (3200b09)
- newclock5:
- Application: Set volume after opening file (0664565a)
- kernel 4.14.y:
- add gpio-key overlay (#2329) (4e50592c)
- add additional overrides to rotary-encoder overlay (#2334) (3cf41641)
- overlays: Add uart0 overlay to change pin usage (bc910e1a)
- Added: [env] PR:2410 (perma): mesa/xf86-video-intel: bump to 17.3.2/028c946
