(2018-01-30, 06:17)smp1 Wrote: [ -> ]I'm not sure when the problem started, I haven't updated for a week or so.
I can easily reproduce the refresh rate issue by switching to any TV channel or playing an interlaced video.
Sample
Thanks, but still can't reproduce.
I normally have OMX disabled/MMAL enabled, and the Kodi codec info (using MMAL) shows the sample as being a 25fps video (no refresh rate change despite my display being set to 60Hz).
However if I enable OMX, the codec info (now using OMX) shows 50fps for the sample, and it changes refresh rate.
But no black screen though (only during the refresh rate change which takes 2-3 few seconds).
I also just tested your sample on LibreELEC Generic (NUC6i56SYH, streaming over SMB over WiFi) and noticed that smb:// streaming is now totally shagged since
PR13401 in #0123, so I may try reverting the chunk size change, or using 64KB as we do with RPi. Playing your sample in #0123 gives:
04:58:00.985 T:140680139622144 ERROR: Read - Error( -1, 103, Software caused connection abort )
and I also get similar errors when navigating smb:// folders:
05:01:29.297 T:140681153701632 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
05:01:29.565 T:140681145308928 ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://USERNAME:PASSWORD@NM-WIN7/Torrent/qTorrent/Samples/DSD'
unix_err:'67' error : 'Software caused connection abort'
05:01:29.565 T:140681145308928 ERROR: GetDirectory - Error getting smb://NM-WIN7/Torrent/qTorrent/Samples/DSD/
05:01:29.610 T:140681153701632 WARNING: Seek - failed to get remaining data
05:01:29.633 T:140680149161728 ERROR: Read - Error( -1, 103, Software caused connection abort )
05:01:30.294 T:140680420640512 ERROR: Previous line repeats 1 times.
05:01:30.294 T:140680420640512 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
05:01:30.914 T:140681153701632 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-2 video
05:01:31.049 T:140680149161728 ERROR: Read - Error( -1, 103, Software caused connection abort )
05:01:31.611 T:140681145308928 ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://USERNAME:PASSWORD@NM-WIN7/Torrent/qTorrent/Samples/VC1'
05:01:31.611 T:140681145308928 ERROR: GetDirectory - Error getting smb://NM-WIN7/Torrent/qTorrent/Samples/VC1/
05:01:31.652 T:140680149161728 ERROR: Read - Error( -1, 103, Software caused connection abort )
05:01:31.679 T:140680420640512 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-2 video
05:01:32.322 T:140680420640512 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
05:01:32.577 T:140680149161728 ERROR: Read - Error( -1, 103, Software caused connection abort )
05:01:33.304 T:140681430861568 ERROR: Previous line repeats 1 times.
05:01:33.304 T:140681430861568 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-2 video
05:01:33.304 T:140681430861568 WARNING: Seek - failed to get remaining data
05:01:33.700 T:140680149161728 ERROR: Read - Error( -1, 103, Software caused connection abort )
05:01:33.844 T:140681430861568 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
05:01:34.230 T:140681430861568 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
05:01:34.541 T:140681430861568 WARNING: Seek - failed to get remaining data
05:01:34.542 T:140680149161728 ERROR: Read - Error( -1, 103, Software caused connection abort )
#0122 is totally fine.
Edit: Tested #0123 with a 1Gbit wired connection and getting the same "Software caused connection abort" errors, so not WiFi related.
