Did anyone notice in recent builds a very annoying speed increase when navigating in a folder using "up" and "down" arrow keys? For example, when I press and hold a "down" key the the files would scroll up at a turbo speed. Same issue with TV channel list.
Also, the DVD/BD playability issues that were introduced in build #0127 are still there and they are totally RPi-specific.
(2018-03-13, 19:38)da-anda Wrote: [ -> ]since I'm thinking about moving over to HEVC from h264 for new encodes I do, is "fastdecode" flag in Handbrake still needed to get decent performance on a PI3, or doesn't it matter that much anymore after all the optimizations done for the PI? I gave it a quick test with a sample the other day, and it seemed to play fine on a non-overclocked PI3, albeit all 4 cores seemed to be maxed out. I tried an older test encode from over a year ago that I remember I had done using "fastdecode" flag, and CPU usage was down at like 30%. So I assume it's still a thing, but I'm not sure if it was just related to the test-sample I did without fastdecode and that a different movie/sample might perform better.
I think you'll be fine with any sane options. Might be worth running bcmstat.sh when playing the file.
If 4 cores are maxed I suspect we haven't even triggered turbo mode and the arm cores are running at 600MHz.
(2018-03-13, 19:41)smp1 Wrote: [ -> ]Did anyone notice in recent builds a very annoying speed increase when navigating in a folder using "up" and "down" arrow keys? For example, when I press and hold a "down" key the the files would scroll up at a turbo speed. Same issue with TV channel list.
Yes, i can confirm this problem is also available with cec navigation (not so hard), but handling with mouse or keypad .....grrr ;-) ...unable to handle
...wrote over this today and last week in terrible english, sorry.
https://forum.kodi.tv/showthread.php?tid...pid2712801
https://forum.kodi.tv/showthread.php?tid...pid2713622
...and last week :-)
Same problem here when navigating in a folder, and when I start a movie and move the mouse, the movie plays in super speed.
Went back to 8.2.3, and everything works smooth.
(2018-03-13, 19:21)doldi Wrote: [ -> ]With #312 i a have yet the problem on my rpi3 and also on a rpi2 with the mouse => scrolling in a big folder and select something is absolutly impossible, also in the skin.
The scrollbar (video/audio) is moving/shifting if i touch the mouse.
Harald
edit: back to 8.2.3 and this all will work fine on both pi.
I'll drop the libinput changes.
(2018-03-13, 18:59)popcornmix Wrote: [ -> ] (2018-03-13, 17:07)rudrood Wrote: [ -> ]Yes, working oke till now. No problems with:
Thanks that is good to know.
@J_E_F_F would be good to confirm if your hevc issue is fixed.
It fails to grab an IP (builtin wifi) so I can't test it, and need to figure out a way to get working firmware back on it, since my Win box didn't see the partitions and I can't connect to it remotely now.
(2018-03-13, 22:57)J_E_F_F Wrote: [ -> ] It fails to grab an IP (builtin wifi) so I can't test it, and need to figure out a way to get working firmware back on it, since my Win box didn't see the partitions and I can't connect to it remotely now.
Can you plug in an ethernet cable?
Can you insert the sdcard into a different PC or sdcard reader? (this should just work and show the boot partition).
(2018-03-13, 23:59)popcornmix Wrote: [ -> ] (2018-03-13, 22:57)J_E_F_F Wrote: [ -> ] It fails to grab an IP (builtin wifi) so I can't test it, and need to figure out a way to get working firmware back on it, since my Win box didn't see the partitions and I can't connect to it remotely now.
Tried that, 3 computers, 2 USB adapters and SD adapters, all fail, it wants to format the card. This may have happened last week when I repartitioned the drive (gparted through liveCD) so I could run the debug builds. Huge pain, but I am finally back up, had to use a chromebook, that is the only thing that could see the drive(s) and I uploaded the current start and fixup files, still had to go in and reconfigure the wireless. Oddly enough, I could not upload into the .upload folder (whole build) from the chromebook, perhaps it sees it as locked.
I'm on the network and up again though. I'll give it another shot.
Second time through, no issues, got an IP and no crashes overclocked playing hevc content. The requested fixup.dat and start.elf are running ontop of #0312
LivingRoom:~ # vcgencmd version
Mar 13 2018 14:01:08
Copyright (c) 2012 Broadcom
version 8dec8950a7fa0b0110b1a747f74d7fc8ae674d7e (clean) (release)
LibreELEC (community): devel-20180312210438-#0312-g6130d1d (RPi2.arm)
J_E_F_F good to hear. Tonight's build should include the updated firmware. Thanks for testing.
New LibreELEC.tv Leia build #0313:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
17863eb7e933ffc4d5bacb025f2ec18b027c301825790418cccc8ac28f8cd8bd
(RPi)
SHA256 Checksum:
efab566b6ac07839f0d922dab50a0b0e02e06a06c5a14a2abc8e6459bbe3b2d0
(RPi2)
text:
# uname -a
Linux rpi512 4.14.24 #1 Wed Mar 14 02:41:33 GMT 2018 armv6l GNU/Linux
# vcgencmd version
Mar 13 2018 18:52:21
Copyright © 2012 Broadcom
version 6e08617e7767b09ef97b3d6cee8b75eba6d7ee0b (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20180314023456-#0313-g9b47b64 [Build #0313]
# Kodi version
(18.0-ALPHA2 Git:89a53e4). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (9b47b64,
changelog) and tip of
XBMC master (01fa6a4,
- Includes newclock5 patches
- Includes latest commits from kernel branch rpi-4.14.y
- Includes latest bcm2835-driver master (3347884, ahead +1)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (54405d9, ahead +120)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (373f726, +5), inputstream.rtmp (9c398d9, +2), peripheral.joystick (d68e78c, +2), pvr.argustv (3556049, +1), pvr.demo (8f62053), pvr.dvblink (594e062, +1), pvr.dvbviewer (05cff5b, +1), pvr.filmon (c7243fb, +1), pvr.hdhomerun (f3e0177, +1), pvr.hts (095784b), pvr.iptvsimple (933a5c4), pvr.mediaportal.tvserver (74e2bea, +1), pvr.mythtv (85c33c4, +1), pvr.nextpvr (aa1c8d2), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (5b47d9f), pvr.stalker (77eec69), pvr.teleboy (3ae0297), pvr.vbox (57f3198), pvr.vdr.vnsi (4db947c), pvr.vuplus (dc230dd, +1), pvr.wmc (e0a9190, +1), pvr.zattoo (3c46173), vfs.libarchive (e74a3ab, +2)
- Exclude [env] kodi-0100-temp-add-pr13594.patch: merged upstream
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: fix PR390
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2511 (perma): kernel-firmware: use project specific firmwares and cleanup
- Include [env] PR:2529 (perma): buildsystem: support get handlers (archive, file, git)
- Include [env] PR:2533 (perma): graphics package updates
- Include [env] PR:2565 (perma): kodi: mid-March update
- Include [env] PR:2577 (perma): buildsystem: simplify SIMD support (neon/mmx/sse/sse2)
- Include [env] PR:2582 (perma): samba: update to samba-4.7.6
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:13274 (perma): Mode whitelist
Build Highlights:
- New firmware (Avoid temporary high clock when switching PLL and divisor, and other platform/power fixes)
- Samba 4.7.6 (security fix)
- [PVR][guiinfo][Estuary] Bunch of PVR guiinfo fixes and improvements
- Drop libinput changes for now
Build Details:
- Firmware (Mar 13):
- firmware: arm_dt: Restore support for user-selected DTB file See: link
- firmware clock: WIP: Avoid temporary high clock when switching PLL and divisor. See: link
- firmware: platform: Make sure boosted frequency uses boosted voltage
- firmware: power: Add 10ms timeout for PMIC voltage control
- firmware: platform: Reduce i2c-gpio clock speed back to 200KHz
- LibreELEC.tv:
- buildsystem: add BUILD_FLAG support (PR:2521, 2 commits, 104 files changed)
- XBMC:
- Scan video title (PR:13519, 5 commits, 11 files changed)
- Use our api to set info on python scrapers (PR:12857, 3 commits, 5 files changed)
- [GBM] add better vendor EGL header compatibility (PR:13643, 1 commit, 1 file changed)
- [peripherals] Make CPeripherals::Initialise survive getting called wh (PR:13644, 1 commit, 1 file changed)
- [PVR][guiinfo][Estuary] Bunch of PVR guiinfo fixes and improvements (PR:13642, 8 commits, 14 files changed)
- VideoPlayer: set starttime to zero if streaminfo is skipped (PR:13633, 1 commit, 2 files changed)
- inputstream.adaptive:
- webm / x-matroska container type detection (373f726)
- kernel 4.14.y:
- New commits in this build:
- added capture_clear option to pps-gpio via dtoverlay (#2433) (d35408f2)
- Updated: [env] PR:2577 (perma): buildsystem: simplify SIMD support (neon/mmx/sse/sse2)
- Added: [env] PR:2582 (perma): samba: update to samba-4.7.6
(2018-03-14, 05:49)Milhouse Wrote: [ -> ]New LibreELEC.tv Leia build #0314: RPi / RPi2(Supercedes previous build)
SHA256 Checksum: 17863eb7e933ffc4d5bacb025f2ec18b027c301825790418cccc8ac28f8cd8bd
(RPi)
SHA256 Checksum: efab566b6ac07839f0d922dab50a0b0e02e06a06c5a14a2abc8e6459bbe3b2d0
(RPi2)
This actually reports itself as
LibreELEC (community): devel-20180314023456-#0313-g9b47b64 (RPi2.arm)
Milhouse and @
popcornmix i ordered today the new raspberry pi 3b+ model will your testbuilds compatible out of the box with this new model?
